I have a Samsung CLP-510 and I want to print 500 copies of the exact same document, which is 2 pages color. When I do this from MS Word, the printer takes about 25 seconds thinking between each copy. It just says "processing". Logically, the way it should work is that it processes the document 1 time and then just prints it 500 times. Is there any way to get the printer to do this? I want to get the 500 copies printed out as quickly as possible. Thanks
    Problem Solver:
  • 10 Answers
CHeck your settings. If they are ok, then try printing the job from open office or wordpad. Are you using 2 sided printing? I have the same printer and it blazes thru stuff like this printing 2 sided and all. Just have problems with using cheap paper (jams).
Posted on Feb 26, 2009
I have a pc and a macbook pro. I can duplex print on the pc but cannot seem to duplex print on the mac using word 2011. How do you duplex print using a mac and printing with a Samsung CLP 510 EMAIL
To print duplex on a Mac:
1. After finishing your document, go to File >> Print. You will see something like the following:tcdb28.png
2. Make sure that Layout is selected: tcdb28_0.png 3. Under two-sided, make sure than Long-edged binding (or something similar) is turned on. tcdb28_1.png
This will allow you to print duplex (two sided) on the Mac.
Feb 09, 2011 | Samsung CLP-510 Laser Printer
I want to know if the samsung colour laser printer has photocopy photocopy capability
As long as your asking about the CLP-510 then the answer is no. It is a PC printer only with no copying capability. Samsung does make some multifunction color lasers that will Copy/Print/Fax and Scan.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | Samsung CLP-510 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
Instead of changing black toner printer (samsung clp-510)is giving error INVALID TONER BLACK
This can happen if you install a CLP-500 cartridge OR a Xerox Phaser 6100 cartridge.
Physically they are the same, but the 'chip' is different.
In the case of the Xerox, it is the programing of the chip that 'tells' the printer its a Xerox cartridge, and the printer won't accept this as valid.
If it's a CLP-500, the three contacts on the side of the cartridge have a resistor (for the capacity of the cartridge) and a falmeproof fusible resistor which resets tha page counter (for that cartridge) when a new cartridge is installed.
Oct 15, 2009 | Samsung CLP-510 Laser Printer
Samsung printer problems clp-510 I've had this printer for just over two years - good printer. However recently it is producing very dirty print outs, there are repeated patterns of smudges. What can I...
Too many things for just one solution, If transfer belt is worn out, you'll get that, color drums can cause that, when the fuser wears out toner sticks and transfers to new prints. You have to unplug machine in the middle of a print cycle before print goes into fuser and determine if the problem is fuser or before
Aug 10, 2009 | Samsung CLP-510 Laser Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
Samsung clp-510 .The image had bad color
please shake well to your toners.then verify your toner. if any scratch is appear then please change the toner.
Mar 20, 2009 | Samsung CLP-510 Laser Printer
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
66 people viewed this question
