Question about Apple iPod touch
How to reset my Itouch without connecting to a PC
When i connected my ipod touch to my computer, my computer turned off.how do i reset my ipod without connecting it to the PC
    Problem Solver:
  • 10 Answers
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
window.google_render_ad();
Posted on Feb 05, 2009
My son has forgotten his ipod touch password help please
  • Connect your IPOD Touch to iTunes
  • Press or Hold the power and home keys 10 seconds.
  • Screen goes black, now release the power button
  • Make sure you do not release the Home key until your iTunes says "We have detected an itouch in recovery mode."
  • After this its simple all you got to do is a simple restore using your itunes
Dec 29, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Tip
Fix Disabled ITouch that ITunes will not recognize
If your itouch reads "disabled connect to itunes" and shows the "locked" icon and your itunes will not even recognize the device and itunes says your itouch is locked and enter password, Here is what you do to restore your itouch: (you will lose all itouch contents but it is worth it as almost all say it is broken and worthless)
1. Turn off your itouch or ipod. Do not have charger / usb connected to ipod or itouch.
2. With device off, connect the charger end of the cable to the itouch / ipod but do not plug the usb into the computer.
3. Open Itunes
3. While holding down the menu button (and I mean keep holding it down), plug the usb into the computer.
4. Wait to see the new wonderful graphic on your device and computer screen that shows that your ipod / itouch is recognized.
Your itouch will start immediately restoring itself and you are ready to fill it up with wonderful images, photos and videos again!
So happy to share this tip. It saved me money and time.
on Jun 29, 2010 | Apple iPod touch
Why is my itouch registering as a digital camera and not a removable drive?
If you are referring to when you have it connected to an PC? This is normal, iPods/iPhones/iTouch register as an removable storage device when connected to an PC. This is useful because you can retrieve/add photo on to your device without using Apple software.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Apple iPod touch
Can not connect to the internet with my new itouch. Have tried all the resets. My password (which is correct) does not seem to work. Says unable to join network. The network is working fine with 2 other...
try unsecuring your network for a test run and see if your ipod can connect if it can theres a problem in the security between the ipod and the router if not then its in the ipod try conecting it to the pc and updating the software its running
Sep 20, 2009 | Apple iPod touch
My itouch says connect to itunes but it wont let me
You will want to reset the ipod and reconnect it to your computer. Below I have posted step by steps on three trouble shooting options. If after a reset it still will not connect to the computer, proceed to step two. Putting the iPod into recovery mode. Then if in recovery mode you can get it to connect to the computer, restore it to factory settings. Restoring it is listed as step three. I left the restore article normal in case you can get it to connect with just a simple reset.
1st reset
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
2nd RECOVERY MODE
Connect your USB cable to the computer without the iPod connected at the other end.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message: iTunes has detected an iPod in recovery mode. You must restore this iPod before it can be used with iTunes.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPod and repeat steps 3-6.
Because you must restore the iPod touch, iTunes will not recover data from the device, but if it was previously synced on the same computer and the same user account, it should restore a backup (if available)
RESTORE Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
If none of this works and your iPod is still under a year old I would call apple. Make sure that you inform them of the trouble shooting you have already done though. They can tend to assume people don't do trouble shooting. GOOD LUCK
May 05, 2009 | Apple iPod touch Second Gen (8 GB,...
My computer doesn't recognize my itouch
Try a hard reset of your device:
Mar 15, 2009 | Apple iPod touch
Reset password of mi ipod touch and i connect to the pc apear escrean sey need the passcode
1. Goto your computer
2. Connect your Itouch
3. Restore your Itouch to factory defaults
4. (Optional) Backup your settings
5. Sync your newly restored itouch
Mar 08, 2009 | Apple iPod touch
Ipod touch frozen on Itune connection
Per the first Google result for "reset ipod touch", http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/ says:
"Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done"
Nov 22, 2008 | Apple iPod touch
ITouch with road runner email
can not vonect to email with itouch tried resetting did not work
May 06, 2008 | Apple iPod touch
Apple iPod touch Logo
335 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
