Question about Microsoft Xbox 360 Console
Sound, no picture on my 360
So my 360 was getting all messed up with my graphics. Everything was kinda black with a white outline around it. So, i turned my 360 off, and tryed it on a new TV, after trying EVERYTHING. My problem was fixed, for a while. Now wen i turn my 360 on i get a message saying "mode not supported. I dont see te 360 menu, but i can still hear it. I just got assassin's creed and i really wanna play it. PLLLEEEAASSSEE HELP ME OUT!
    Sniper:
  • 57 Answers
Hi there i have repaired many 360 consoles this is a comon problem the gpu chip inside has pritty much had it and died, you will still get sound but no picture this realy isnt repairable nothing short of getting another motherbord for your xbox,
Not is all lost yet xbox will replace your motherbord inside your xbox for free as long as its still under waranty if not when you call them tell xbox that before you lost the picture you had 3 red lights appear on the front of your console this repair is covered for 3 years from date of purchase
you can contact xbox with these numbers for the uk
0800 587 1102
or +44 20 7365 9792 from a mobile phone
Hearing Impaired (TTY device):
0800 587 1103
Hours of operation:
Monday-Friday: 09:00-22:00
Saturday: 09:00-20:00
Sunday: 09:00-17:00
or if in the US
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time if you live in any other Country or Region please go here to get the correct number http://www.xbox.com/en-US/ChangeLocale.htm its always better to speak to them on the phone as creating a repair online cant be a pain Hope This Helps GOOD LUCK
Posted on Feb 05, 2009
Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
May 19, 2009 | Microsoft Xbox 360 Console
XBOX 360 NTSC only Black and White
yes xbox 360 NTSC only in black and whit colours
Feb 06, 2009 | Ulead Videostudio 8 for PC
When i turn it on there's no picture
Replace your cables for the xbox im betting one of the contacts i worn, borrow a set from someone if you can and see if it fixes it.
Dec 12, 2008 | Microsoft Xbox 360 Console
No picture but sound on my xbox 360
Connect it to a different TV. If the problem persists then most likely the wires are the culprit.
Nov 22, 2008 | Ulead Videostudio 8 for PC
Video no longer works, only sound
Hello!
This is similar to the Red Lights Of Death. But instead of your CPU having a bad connection, it's your GPU. There is a 3 year warranty on the 360, so call Microsoft and get it repaired or replaced. If the warranty seal is broken you can take it apart and replace the x-clamp with 4 screws, 8 fiber washers, 8 steel washers and heat sink paste. Contact me for further instructions if doing it yourself. I hope this helps.
Good luck and happy gaming!!
Aug 21, 2008 | Microsoft Xbox 360 Console
XBOX 360
check connections.
e-mail me at B3652@live.com
May 31, 2008 | Microsoft Xbox 360 Console
No picture for game
get it checked out.
Apr 12, 2008 | Sylvania 6427FF TV
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Quickcam Pro 9000 Problem
u try to mess around with master settings of web cam cheak and uncheak few things in the options menu of cam see if u can get itto work are useing usb 2.0 ports
Jan 07, 2008 | Computers & Internet
62' Mitsubishi WD-62525 little black and white squares instead of picture but I have sound
Mitsubishi list this problem and has a solution of replacing several small surface mounted caps and diodes. we have tried this repair 5 times and only successfully done it once. so replacing what is called the formatter board part # 930B924002 for around $ 350.00 usually repairs this type of failure, However changing this board is a time consuming thing and takes a lot of Patience. It is buried deep in the set and several other board have to be removed just to get to it
Oct 17, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Microsoft Xbox 360 Console Logo
117 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
