Question about Veo Velocity Connect Webcam
Video quality is poor
Picture is fuzzy and dim
    President:
  • 8,637 Answers
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Posted on Feb 06, 2009
Poor picture quality
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Poor picture
its a mainboard issue .It can be fixed easily by replacing the mainboard or the hard way by fixing the excact one (the second option requires advanced electronics and expertise
Jun 18, 2014 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Amp transmitting fuzzy picture
It could be dirty contacts, corroded connectors inside, or dirty from atmospheric pollution or even dust.
Other degradation may result from a solder joint developing corrosion now, or a diode getting leaky.
It is repairable, but it is a time investment.
Mar 23, 2012 | Channel Plus DA-8200HHR Amplifier
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
The picture quality is very poor. Picture is fuzzy.
Did you turn the ring on the camera itself? The camera does not automaticaly adjusts itself. You must turn the lens to focus manualy.
If nothing works and you just bought this camera, call microsoft and they will help you more.
Mar 05, 2010 | Microsoft LifeCam VX-3000 Web Camera
Poor quality video transmission on new webcams
The camera lens can be focused by turing the lens from Left to Right. Sounds like this may be the problem. Hope this helps. Bud
Jan 04, 2009 | Logitech Webcam
Logitech Quickcam Chat
Hi Thomas,
Have you tried adjusting your resolution? To maximize the quality of video/picture that your webcam can capture, Turn the resolution into 1.3megapixel. Adjusting the resolution is by clicking the arrow above the Video Option.
Oct 25, 2008 | Logitech Quickcam Chat Webcam
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Logitech Webcam
Logiteck quickcam communicate
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Troubleshooting: Image Quality for Cameras trnsp.gif Detailed Description This article covers some standard troubleshooting for issues such as fuzzy, grainy, out-of-focus or off-color camera images. trnsp.gif Answer The information in this article applies to the following software
QuickCam 9.x and below
ImageStudio 7.x and below
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Mar 05, 2008 | Logitech QuickCam Communicate STX Personal...
Night time pic mode
The one thing I have noticed about the DV179, is that it takes poor quality photos and video, unless it is in pure sunshine... :)
Yes, zooming in does distort the pic's, so be sure to put the stabilization mode to 'on', this does help a bit.
Dec 27, 2007 | Jazz DV-179 Digital Camera
Veo Velocity Connect Webcam Logo
217 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
