My computer does not recognise me as the administrator
My computer will not let me change any settings or download any updates because it tells me to contact the system administrator. This is my home computer and I am the only user so how do I convince the computer that I AM the BOSS???
  • bcole6_22 Feb 04, 2009
    Solution does not apply. The start button only gives three options; stand by , turn off , restart..... there is no log off option.
    President:
  • 2,692 Answers
START - LOGOFF - SWITCH USERS - OPEN ADMINISTRATOR ACCOUNT.
Posted on Feb 04, 2009
  • Thomas F. Schneider Feb 05, 2009
    What version of windows are you using?  Password protected? Try this; When starting the computer  ,press F8. Go into windows that way,minimized and see if you can then do it.
My SPD-S flash card is not recognised
this sounds like a driver problem
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
http://download.cnet.com/o2micro-flash-memory-card/3000-18492_4-163841.html
hope it helps
Apr 12, 2012 | Computers & Internet
Tip
How To Diagnose Timeslips v9.0 and Higher
This feature is only available in Timeslips v9.0 (Service Release 11), v9.1, and higher. If you have a Service Release of Timeslips v9.0 lower than SR11, please download it from <a href="http://www.timeslips.com/Support/downloads"><b>http://www.timeslips.com/Support/downloads</b></a>. Be sure to install the update on each computer that has Timeslips installed.<br /> <p style="font-style: italic;"><br /><br /> <p style="font-style: italic;">If you have not already installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator. If you are using Timeslips v9.0, then you must reinstall SR11.<br /><br /><br /> <p>We recommend performing this procedure on every computer when you:<br /> <ul> <li>First install Timeslips</li> <li>Update Timeslips</li> <li>Update your computer's operating system</li> <li>Experience data corruption</li> <li>Experience errors starting Timeslips that tells you to use this feature</li></ul>Prior to performing the Diagnose This Computer procedure you must exit Timeslips as well as any other program which may access the Borland Database Engine (BDE). If you are unsure what programs may use BDE, close all other programs.<br /><a></a><b></b><br /><br /><a></a><b>Steps to perform the Diagnose This Computer procedure:</b><br /> <ol> <li>Close Timeslips and any other program that uses the Borland Database Engine (BDE).<br /><b>Note</b>: If you are unsure what programs may use BDE, close all other programs.</li> <li>Open Station Administrator on the computer you wish to diagnose.<br /><b>Note</b>: If you have not installed Station Administrator, install it from your Timeslips CD-ROM using the Custom installation option and selecting only Station Administrator.<br /><b>Note</b>: If Timeslips is operating in a network environment, and Station Administrator is not installed on the workstation, then use Windows Explorer to locate and run <b>Statadmn.exe</b> from the Timeslips installation folder on the server. [From the Windows Toolbar select <b>Start</b>; <b>Run</b>; <b>Browse</b> to locate and open <b>Statadmn.exe</b> from the Timeslips installation folder on the server.]</li> <li>In Station Administrator select <b>Options</b>; <b>Diagnose</b> <b>This</b> <b>Computer</b>. Click <b>OK</b> to confirm that all programs using Borland Database Engine are closed. Station Administrator will attempt to analyze your system.</li> <li>When <b>Analyze System</b> completes, the Diagnose This Computer dialog box will open and alert you to problems with your Timeslips database and operating system. Each of the four areas has an associated Fix button. If any Fix button is enabled, click it to either solve the problem or receive instructions for doing so. Click <b>Help</b> for further information.<br /><b>Note</b>: Even if no problems are reported, Station Administrator may make other necessary changes (<a href="http://kb.sagesoftwareonline.com/cgi-bin/sagesoftwareonline.cfg/php/enduser/popup_adp.php?p_faqid=14967&p_created=1122586187&p_sid=TUvWvcnk&p_lva=15461&p_li=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjE4LDIxOCZwX3Byb2RzPTUxMzQsNTE0MCZwX2NhdHM9JnBfcHY9Mi41MTQwJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*#does">see above</a>). </li> <li>If you have experiencing data corruption errors click <b>Change Operating System Settings</b> to open the Windows 95 and 98 Settings dialog box and unmark <b>Enable file system caching</b>. Click <b>OK</b> to return to the Diagnose This Computer dialog box. </li> <li>Click <b>Done</b>. If prompted to do so, restart your computer.</li></ol>
on Feb 21, 2011 | Computers & Internet
When i plug in my tevion video capture device to the usb port it makes the recognise sound, but im unable to capture video. Whats up???
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps
Aug 13, 2011 | Computers & Internet
My computer will not recognise my device. Also I can't set up an acc to buy books it doesn't like my card.
sounds like a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 30, 2011 | Computers & Internet
When camera sd card is entered into PC it is not recognised and cannot proceed to download pictures
if you are having trouble with your sd card being recognised this might be the drivers
Mar 23, 2011 | Computers & Internet
I can't change my settings for updates. It tells
You would have to log into your computer under administrator. You may need a password. If you are not the administrator or do not have the password you can not change settings on the computer. You can try going to the control panel and clicking on users to see user information.
Sep 19, 2009 | Computers & Internet
I have Vista Home premium and I am set up as administrator, but when some of my software (accounting) need to download updates, the computer tells me that I do not have rights to do this and to contact the...
hello my friend kindly check your account privilege and rights and enabled write and read options in order to update. You can go to control panel then user accounts to enable and change rights
Jun 16, 2009 | Microsoft Windows Vista Home Premium with...
Need to set up Vista computer's for others to receive automoatic updates without alloinw them administrative passwords or priviledges
Go to the Start menu and select Control Panel
In the search box, type in "update."
Click on the link to turn automatic updating on or off.
Select from the available options including the time you'd like updates to be downloaded and whether you'd like to be notified and asked before downloaded updates are installed.
1. Go to Start button > All Programs > Windows Update.
2. In the left pane, click Change settings.
3. Select Install updates automatically.
4. Under Recommended updates, select the Include recommended updates when downloading, installing, or notifying me about updates check box, and then click OK.
5. Make sure you click Check for updates to make sure your computer has the latest updates installed. You might need to shut down and restart you machine after the updates are applied.
May 06, 2009 | Microsoft Windows Vista Business Edition...
Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Mar 22, 2009 | ASUS Computers & Internet
My hp pavillion a1013w does not let me update drivers.
Someone uses your computer and create a user accout. Please check this.
Follow this simple solution:
1. Restart your computer
2. Press F8
3. Select to start your computer in SAFE MODE
4. Press Yes whenever you ask something
5. Go to Start-Setttings-Control Panel-User Accounts
6.Change everything, the user name and password
Please don't forget to rate this.......
Nov 24, 2008 | HP Computers & Internet
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
