Fujitsu 24C1 Air Conditioner
Problem for Fujitsu 24C1 Air Conditioner
Remote unit slides open but cant find battery cover-model AR-DL10
By ian7654 on Feb 04, 2009
It is about 2 to 3 yrs old and I think we need new batteries. It has a sleep button at th etop left and a Timer button on top right. I cant figure out where the battery hatch is. I assume we need to get the slider off and maybe it is there?
Also, where can I buy a new one?
Thanks, Ian ian@spibooks.com
or 212 431 5011
Best Solution
posted on Jul 02, 2009
Very Helpful)
philmac1
Rank: Apprentice
Rating: 100%, 3 votes
keep the slider closed and using a flat screwdriver carefully pop off one side and the slider will clip off the batteries are behind it
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Feb 04, 2009
Very Helpful)
bobotfel
Rank: Guru
Rating: 87%, 282 votes
Yes it is at back of slide door of your remote, slide down the remote control door and remove it then you can see the battery inside.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Apr 21, 2009
Helpful)
eljefegeneo
Rank: Apprentice
Rating: 94%, 4 votes
When sliding the bottom part of the remote down, you have to lift it slightly (I did this with a letter opener - very carefully) to pry the door up from two stops that normally prevent the dorr from sliding down too far. If you look carefully, you can see what I mean.
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 24C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 24C1 Air Conditioner
Do you recommend Fujitsu 24C1 Air Conditioner?
Answer
Answer
can not see screen, and do not know how to change battery
Answer
Internal unit timer light flashes twice then pause and repeats itself. outside unit does not come on... (More)
Answer
Which picture do I need to cool the house with a fujitsu ducted air conditioning. The picture of the... (More)
Answer
the end of the louver is broken and need louver parts
Answer
The lights flashing on the unit are the yellow and red. When powered off, it does not turn off. We... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 24C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1200
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
