Question about VistaQuest VQ-5115 Digital Camera
How do I put pictures in the key chain slide show thing?
I plug in the USB connection to my computer but it doesn't show any new drive showing up. My camera is the VistaQuest VQ500.
  • minimouse114 Feb 16, 2009
    i cant put pictues on the key chain
  • elkristo Mar 09, 2009
    the first time i used this camera i plugged it in and the windows menu popped up it loaded fine. i just went to try it again and instead a menu popped up saying "open with these programs" but NO programs are even listed, i downloaded the driver which installed a photo program, and that wont load the pics, it just acts like i never pressed the button. everywhere else i try to load it from says the camera is either busy or cant be detected. im very irritated with this camera.
    Problem Solver:
  • 16 Answers
Make sure the camera is on when you insert it via usb, check in the camera setup that it is set for PC USB.
Did the camera come with any drivers?
It is possible that the camera needs additional driver in order for it to operate correctly on the PC.
What operating system are you using?
More detail would be helpful, but what does it say on the screen when you plug the camera in?
Does it install it correctly or does it say there is a problem?
If it loads correctly the a new drive should appear in 'My computer'
Come back with more detail, I might be able to help more
cheers
Bri
Posted on Feb 04, 2009
  • Brinip
    Brinip Feb 05, 2009
    OK I am fine if my info was not helpful but....
    How is that 'inappropriate'?
    You give hardly any information, I try and help and then get a 'inappropriate'.
TV is not showing the USB data
maybe you did not properly select the right application in your tv... example if you play movies go to movies menu and if thats music go to music menu and also for pictures go to picture menu......or the format of you data is not supported of you TV..
Jan 12, 2014 | Computers & Internet
How can I see my pictures from mi mini camera Key Chain
all you need to do is connect it to your pc using a usb cable and it will show up as a drive. look through any folders to find the pictures.
Jul 18, 2013 | Mark Feldstein Minidig Key Chain Mini...
Computer doesn't recognize Canon IXUS 130 when connected
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Jan 09, 2012 | Canon PowerShot SD1400 IS IXUS 130...
Hello, My computer is a dell labtop with windows XP. It will not allow me to plug in my usb for my camera or my new vivitar digital key chain usb to upload pictures. As soon as I plug the usb into the...
try connecting to a different usb port and if still that happens ...remove the motherboard drivers and restart the system and than plug in the camera if it doesnt restart install the drivers again from the dell support website ... support.dell.com u have to put in ur service tag and than down load the drivers required and see if the issue is resolved or not if not than u have to reinstall windows
Dec 24, 2010 | Computers & Internet
The antec mx25 doesn't show up on my computer when I plug it in. It's from a busted lap top of mine, and I'm hoping the hard drive itself isn't shot, but I'm assuming that the mx25 would still register on...
Mine did the same thing and after searching through countless google searches, I was ready to take it back. However, when I opened it up to take out my old laptop drive I noticed that the drive was not connected properly. It is possible to simply slide the old drive under the proper connectors where it will seem like it is connected fine. You may notice that it sticks up in the back a bit. Remove your drive and make sure that it slides in and connects flush. Once I did this, I plugged it in before screwing the case back together and my computer recognized it right away. I plugged the red USB into my PC only. Good luck.
Dec 21, 2010 | Antec MX25 25Inch SATA Hard Drive...
http://www.vistaquestusa.com/pages/service.htm
Click this link and find your camera to view the pdf manuals for your keychain (viewer) and camera. The pdf will explain how to connect your keychain to your computer to put pictures on it.
Good Luck! : D
May 26, 2009 | VistaQuest VQ-5115 Digital Camera
Insignia digital keychain from Best Buy cannot download program
Plugin the keychain to the USB
The keychain shows up as a CD Drive in My Computer.
Open up the drive
Copy the file ImageViewer4.exe to the Desktop
Run ImageViewer4.exe by double clicking on the file
The pictures have to be in the folder My Pictures; they will not work within a folder that is inside the My Pictures folder
Now you should be able to select and add your pictures from the My Pictures folder
If you still get an error, click on the Format Device button and then try the above again.
Jan 03, 2009 | Computers & Internet
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
How can I copy pictures from my pc to my kodac ex811
You must first install the drivers that came with the frame.
Then connect using the supplied usb cable. If the drivers are installed, it should just show up in you windows explorer like any other removable storage would.
You can then drag and drop the pictures you want to copy from your computer to the frame. Or right click on the picture you want to copy and then scroll down to "send to" and click on the removable drive associated with your frame (usually drive e, f, or g depending on your computer configuration).
You may also use the EasyShare software supplied with the product.
The frame does not have very much internal memory and will fill up quickly with high resolution pictures. It may be best to just put your pictures on a usb thumb drive and plug that into the frame. Then turn on the frame and a slide show will start automatically.
Jul 08, 2008 | Computers & Internet
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
VistaQuest VQ-5115 Digital Camera Logo
146 people viewed this question
Top VistaQuest Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a VistaQuest Camera Expert? Answer questions, earn points and help others
