Question about Samsung SYNC SGH-A707 Cellular Phone
Wet phone I DROPPED MY BRAND NEW TOUCH SCREEN ETRNITY PHONE IN TOILET WATER. ONCE I FIRST RETRIEVED MY PHONE IT WAS WORKING PERFECTLY FINE BUT THEN ABOUT AN HOUR LATER IT WAS BLINKING ON AND OFF. I HAD USED A BLOW DRYER HAVING IT ON LOW TO DRY IT FOR ABOUT ONE MINUTE AND NOW I HAVE MY PHONE DISASSEMBLED TO AIR DRY WILL THIS WORK???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Yes in some cases. but since you switch on your phone without completely drying it out, some problems may arise... like, auto-shut off, no signal, no ringtone, not chraging and even worse, it might die... in cases like wet phones.. it should be dried out completely to avoid shortages on the electronic components. but anyway... try cleaning it with laquer thinner for a minute or two... this will remove the moist deposits that might have developed on the ic's..
tnx
Posted on Feb 04, 2009
Dropped my phone in water and now the touchscreen doesn't work at all
Hello there,
You will have to disassemble the phone, then try to dry it with a hand dryer. Do not place it too close to the phone so you will not damage any part inside the phone. Then reassemble the phone back together and the touch screen will work perfectly fine once again.
All the best. Elect_Comp
Sep 13, 2011 | Pantech Cell Phones
My screen on my phone has turned white but the keys still work
If your phone has been dropped it may have knocked the pin plug inside it loose, causing the screen to fault, also, if it has been wet or moisture has gotten inside, many phone brands will do this as a 'warranty fail safe' so people who drop their phones in toilets dont get new one under warranty. If your able to open the phone, check that all plugs are inserted properly and also try presssing along the edge of the screen as their may be a bad pojnt of contact causing the problem. I hope this helps. Good luck.
Jun 20, 2010 | Motorola Mobility ROKR E6 Smartphone
Dropped in toilet
Congratulations!!! remove every parts you can i.e. battery, SIM card and memory card. Make sure each and every single drop of water is out. Wrap the mobile phone thick with a piece of cloth and keep it on a warm place ( Not too warm ) like Above the TV( thats the best i can suggest) for couple of days, 3-4 days will be sufficient. Make sure you don't switch it ON while its wet otherwise the Flash IC might get fried by the battery. After 3-4days of evaporating the water from your Mobile, keep fingers crossed and switch ON the Mobile. If switched ON perfectly for 10-15 minutes (try checking all the feature in this time period) the mobile phone is in good status and if it doesn't kindly purchase a new Phone because i won't suggest you to get it repaired as once Nokia phone goes for a repairing it will always ask for repairing after 2-3 months.
May 05, 2010 | Nokia Intrigue 7205 Cell Phone
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
I dropped my LG VIEW in the toilet and everytime i turn it on it says "emergency download". what should i do??
I would take it to your phone service provider...you will probably will have to get a new phone.
Sep 02, 2009 | LG CU400 Cellular Phone
I have the same problem!!!! I just dropped mine 2 hours ago!!
Jun 04, 2009 | LG Vu CU920 Cellular Phone
I dropped my LG enV into a puddle of water.
Sounds like you will need a new battery. My env2 would only work if plugged into the wall charger after I dropped it in the toilet. I got a new battery and it works fine now!
Mar 12, 2009 | LG enV VX9900 Cellular Phone
Flashing blank screen
If your phone is less then a year old bring it to a store that is owned by Verizon. You could also call 1-800-256-4646, then ask for the FRU (Factory Replacement Unit) department. They will get you a replacement phone.
Jun 27, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
