Pc won't connect to printers or internet on existing LAN network. shows ip is connected but won't load webpage or print.
  • 4 more comments
  • Ken LaPoint Feb 05, 2009
    That would be a good idea if all the other computers weren't MACS.
    I'm not aware of any workgroups on the Mac comps..
    Printer is etherneted on a jet direct fine on the macs.
    computer is an Emachine, and is LAN cabled and there are 5 other macs working fine on the network and printer is a network laserjet 4000 and works fine on the macs
    Not sure that workgroup names pertain to Macs... help
  • Mike McWhinney May 11, 2010
    Can you ping the pirinter by IP address? How is the printer networked? Does it hve a straight RJ-45 connection or is it shared by attached from another PC?
  • Terrence Hyden May 11, 2010
    what kind of computer do you have?
    are you connecting to LAN via hard line or wireless
    are there other devices currently working on the network?
    is printer local or network?
  • 596 Answers
Verify your pc is in the same workgroup. You can do this in the control panel, systems. You will need to reboot after you make a change in workgroups. (If you need to make the change.) If you are in the same workgroup, go into your command prompt windows, and type "ipconfig /all" This will show you full configuration on your network. Good Luck.
Posted on Feb 05, 2009
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Every time i have to press start button to take print. after print command it not directly print and also not print continuously.please help me to solve this problem. thanks
is that network printer find that ip and open webpage nput that ip (u should connect with lan cable) i think there is option for continuous printing
Aug 11, 2013 | Panasonic KX-MB1500 Monochrome Printer...
try to ping a webpage URL from a dos prompt to verify that an internet connection exists.
Dec 21, 2012 | Computers & Internet
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
Hp pavilion a330n Internet Explorer won't connect.
check your IP Adress settings are correct for this machine,
Go to start ,then click on run,Type CMD,Then type IPCONFIG/ will show you a list of all the devices connected to your machine and your local network,
Have you got LAN & WLAN adaptors on board?
this will explain your message,
you will have to set the ip settings on each adaptor
ie LAN and WLAN
This wiil help determine which adaptor is to be used when connecting to the network and the internet.
If your using wireless on computer to connect to the internet then run your wizard to help setup the connection
Same for the wired LAN ,use your wizard
The settings for your modem can be reset easily and your ISP will help get you connected to the net because you already have an account with them,
Apr 10, 2010 | HP Pavilion a330n (Refurbished)...
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Can't figure out how to connect my printer to the "network"... hope I'm using the right terms. Had it all set up to a dlink wireless router with a modem and had to disconnect it all to resolve another...
connect a lan wire from router to printer
print printer information
find out ip
pls add static ip address on the pc(printer and pc should be in one network)
type ip address on the internet explorer
change the ip address of your router class ip network range
remove static ip from pc
Oct 28, 2009 | Brother HL-2170W Mono Laser Printer
I have a zyxel router, after connecting to the laptop via wireless, sometime it cant load the webpage such as but the wireless signal there showing "Connected" with full tab. After once...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jul 01, 2009 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
Network printing (network port)
The copier and the workstation should have IP addresses from the same LAN class.
Open any internet browser and try to see the printer's webpage - Command Center by typing the printer's IP address.
If you see it = OK if no then something is wrong with the network ...
If you are using a router/hub check if you have a green light for the printer port at the router/hub and at the printer - ussualy a green light indicate OK
If the cables and the rest of the network hardware is OK do a ping from your computer to the printer.
In windows XP: Start->Run-> type cmd
then: ping xxxx.xxxx.xxxx.xxxx
whre xxx = printer IP address
you should see a replay if everything is OK
A very simple check is to bypass the whole network infrastructure (which may be at fault) by connecting the PC or a laptop direct to the printer using a cross-over network cable. Give a static IP to the printer and a static IP to the computer. from the computer you shoould see the printer webpage (open any internet browser and typ the printer's IP Address)
Sometimes for security reasons routers have ON some filters - check any firewals about MAC / IP filters or ports. To print using the network printer you need to let open port 9100.
Oct 23, 2008 | Kyocera FS-1118MFP Laser Printer
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = Subnet Mask = IP Adress = alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
David Payne
David Payne
