Question about Home
Yellow ring around jacuzzi...
There appears to be a yellowish, almost grease looking, material around the jets. After draining the jacuzzi there is a yellow ring left around where the top of the water was when it was filled. The jacuzzi is now 9 years old and has been doing it since Day 1. Any help would be appreciated!
  • 2 more comments
  • savtaman Feb 04, 2009
    I'm not sure if that's what it is. It's been doing it from the start, and it's a consistent amount that's left on the tub. Wouldn't more come out the longer you'd use the jets?
  • Thomas F. Schneider May 11, 2010
    Maybe you are right. I guess you could have it analyzed . Or at least take some and put it in a glass of water to see if it floates to the top, thus confirming a hydrocarbon of some sort. Tghe other possibility is that the hozes are breaking wdown but I don't know why that woudl be from the start either? Interestign dilemma.Sorry I wasn't able to be of more assistance.
    Pump bearing /seal leaking,leaving a residue of oil?
  • Marcel Lemieux
    Marcel Lemieux Nov 05, 2017
    Make sure you have your water tested and that you add the proper chemicals to the water!!!! High PH can cause scaling leaving brown nasty ring in hot tub! Ask dealer about this and have water tested! Best move ever!!
My girlfreinds Parents just baught a hot tub, before my g/f came down to use it, it never had the problem, and then when she did start using it, they started noticing a yellow slimmy ring around the top were the water line is and around the jets, they called and asked thinking it was the motors or somthing, They said does anyone where lotion? Sure enough my g/f cakes the stuff on. Now befor shes even aloud in the tub, shes gotta take a full shower with No lotion.. Check to see if anyone in your house hold is using lotion?? Because everytime she or they get in with the lotion on there skin, you or sombody will have to drain and fill up again, which with water and all the chemicals is like 37 dollars each time. We dotn know exactly why it does but my best guess is, It has some kind of chemical reaction, with the chemicals they use, and with it being a hot tub pores of the skin open up which prob, release the lotion. Iv try convincing them to use chlorine, instead of the other stuff they use but the girls complain it drys there skin, I Swear by Chlorine, everytime i use it, its always lefts the water sparkling clean, Hope this can help, but im sure somebody is using lotion. Have them tottaly rinse off befor getting in. Or dont get in
Posted on Sep 13, 2009
  • cathy miller
    cathy miller Dec 04, 2013
    This happened to me when I used any type of bath salts, bubbles, or bath additive.
    Problem Solver:
  • 6 Answers
Run fresh water around the jacuzzi it sounds like grease lodged around the pipes of the unit to motor , leave running for half a hour and drain again ???
Posted on Feb 04, 2009
Jacuzzi hot tub replacement jets
your local jacuzzi dealer should be able to source you some parts , but i can tell you if it's only a o-ring failure these are avail from your local hardware store , as most jets are rebuildable , some are not look at back for screws to see if they are or not
May 20, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
My wife was given a ksm90 blender. It looks like it was never used. It had a few yellow spots of yellowish greasy material on it (gear grease ?) When I started it up it had kind of an electricalish...
it should be high temperature grease. it will only drip out if the seal has dried out or cracked.i think the seal has a spring inside it may need changing they should be cheap.and easy to change. or you could always put some flour in the bowl and run it for a few minutes to see if it dries up it may just be lack of use.
Dec 20, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Black spider like material that may come from jaccuzi
Is it greasy, oily spider web type junk? Coming through the pipes, new construction or new tub? Could be from the pump, not that it is leaking oil but it has oil in it from the manufacture of it. I would call the jacuzzi people and tell them what you have and that your kids play in the tub and drink the stuff, ought to get them to move on that one. Ask them if they know what it is and what to do about it? Hope this helps.
May 21, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
Yellow ring on screen of KDF-E50A10 Sony Wega
The optical engine has a build up of dust. This can cause yellow shapes and blotches to appear. It is no easy task on this model to dismantle and clean the engine.
Sep 28, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Two person jacuzzi that hasn;t been used for several years. Iron
You are on the right track. Be sure and chlorinate and run the jets at the same time I would let it set for at least a couple of hours running the jet intermittantly and then drain and repeat.
Sound like you have Iron Bacteria. You may want ot contact a water profeessional who can recommend ways of getting rid of the iron.
Properly Chlorinating your well would be a good first step.
What part of the country are you in>
sanray
Dec 19, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Indoor jacuzzi bathtub problem
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Nov 27, 2008 | Home
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Home Logo
2,092 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
