No signal from computer to monitor 8/13/08!
This monitor has been flawless, thank God, since I first got it from Gateway back in August, 2006. I have not had the problems others have had until now. The monitor was working fine up to Tuesday evening. Early Wed. morning I turn on my system as usual and the monitor says "NO SIGNAL" and the power button goes from blue to yellow. I made no changes -- did nothing from Tuesday evening to Wed morning -- and this happened. I thought it was my computer but I heard windows XP and my desktop was "there" but I couldn't see it!! So I turned everything off and I got out my old Gateway FPD1810 monitor, hooked it up to dvi port from computer and all was fine!!! So I know it is NOT my computer or graphic card. Remember I made no changes to anything and this happened all of a sudden. I know that people have spoken about the dvi port on this monitor as failing all of a sudden, but on my monitor the dvi port still works with my Cablevision HD box and my Toshiba DVD recorder. I watch high definition television and watch dvd recordings still on this monitor!!
My issue is that my computer and the monitor are not syncing and I get no signal, no computer display! I still do get my cable box and dvd recorder! So my monitor is NOT dead -- it still functions beautifully with its menus and I can still watch HDTV, etc.
What is happening here? This problem just came out of the blue, with no provocation from me -- I did not download anything, make any changes to anything, period!
mcartolano@aol.com Same problem, no signal to monitor. I have replaced the video card with no luck. Any suggestions as to what it may be? Motherboard?
  • Thomas F. Schneider May 11, 2010
    Is not the only thing left the cable and connectors?
  • 106 Answers
Maybe your monitor is too old to your pc.. because it can't catch up the HI frequency of Graphics that you set up in your system.. but lets check first your system.. you need to get a new monitor or an extra one taht can capture the frequency of your system.. then ill give you the step.. here it is.. in windows XP,, right click on desktop then properties.. after you click the properties a windows will appear.. display properties..go to setting, below click advance., then find monitor in general tab. then you see there the monitor setting... try to change it to 60 hertz... then restart your pc then try to use your old monitor.. ^^
Posted on Feb 09, 2009
Gateway 4300 monitor doesn't come on at startup
1) tes the power cord 2) and see if the monitor have the anomaly in another computer. If do not the Motherboard from CPU is faulty. However RUN the software diagnostics coming with Gateway for any component HARDWARE faulty.
God bless you
Oct 17, 2012 | Gateway Computers & Internet
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
X2gen mw19u monitor is off but the ''no signal'' light keeps flashing on and off. When I power up the computer, it continues to flash on and off. You can see that the computer is powering on and going...
Hi Steven,
You are getting "No Signal", indicates that CPU is working fine. Check with another monitor or desktop, if it is working gateway monitor is in risk. I recommend you to check with Gateway technician.
Jun 14, 2010 | Computers & Internet
Ghost images and vertical lines on new FPD1775W monitor
You going to need a new logic board inside witch controls the signals from your video board on your computer. that is the only fix there is that i know of and I been around the block a few times with gateway.
thanks please do leave postive rating and feedback Thanks
Oct 09, 2009 | Gateway FPD1775W Monitor
My monitor light comes on but there is no signal.
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Jul 29, 2009 | Gateway FPD1775W Monitor
I tore down and reset my computer in a new location. After reconnecting everything my gateway 900g monitor is not receiving a signal from the cpu. There is a signal coming from the computer, I don't know...
Check the cable connections, and make sure you did 't accidentally bend a pin when reconnecting things.
Also you may wish to contact gateway online to see the troubleshooting solutions for your particular monitor. There may be a reset you can do.
Also troubleshooting is available from Help & support in your start menu...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Computers & Internet
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Asking support for getting drivers to 610 Gateway desktop computer
If its just the drivers u need, go to www.support.gateway.com and download it from under your model no.
Oct 23, 2008 | Gateway FPD 1810 18.1" Flat Panel LCD...
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Computers & Internet Logo
331 people viewed this question
David Payne
David Payne
