Question about Sony KP-57WS510 57" Rear Projection HDTV
Screen flashes green a couple times then shuts off
The problem started with small horizontal green lines. then the t.v. started flashing green on the whole screen then shuts off completely.
  • Sony Master
  • 8,617 Answers
You need a new green CRT. The lines were retrace lines which are the first sign of a tube developing a short eventually the green will short completely and cause the set to shutdown.
Posted on Feb 04, 2009
My sanyo lcd 50" tv is flashing green blue red colors across screen?
Sounds like display panel fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Televison & Video
There is a sound but no picture in to the screen and there is horizontal line
Tv have a Horizontal IC out is dead or cold soldering.Make a fist with ur hand,bang on the tv frame bazel a couples of times.If the hoizontal line flashes back to normal screen?Tv have cold soldering around horizotal IC area.U have a soldering iron tool and a roll of solders,know how to do basic soldering?Take the back of the plastic screw driver tap around for cold soldering area.Resoldering those area.No horizontal tv screen flashes back the IC out is dead,require replacing another horizontal IC output.
Mar 21, 2011 | Televison & Video
Horizontal flashing line at the bottom of screen
I am sorry but, usually, that is the start of the screen's LCD failing, it will most likely get worse over time... This is caused by the "Driver" transistors failing....
Mar 07, 2010 | Compaq Presario Notebook
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
I was getting nine flashes and know the green crt
Sounds like a bad green crt. These Sonys are bad about that.
Jul 06, 2009 | Sony KP-65WS500 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Flashes blue and then the tv shuts down
The tech is correct about the internal short inside the blue CRT. There is a way to remove that short by applying a small amount of current to burn the short but that might damage the CRT even more. At this point the CRT needs to be replace.
I will post the instructions on how to remove that short but you will need to have a good regulated power supply and limit the amount of current to 1 to 2 amps.
Apr 24, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
