Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Only suction to attachments
I get suction to the attachments for my Kenmore Progressive bagless upright, but no suciton for floor cleaning. The brushes are turning, but there is no suction there.
  • 4 more comments
  • sisboldt Feb 04, 2009
    Mr Mark - thanks for that suggestion, but I've checked that out and there is nothing stuck in the throat. Is there some sort of sensor where the hose attaches back that might be bad?
    Thanks
  • sisboldt Feb 05, 2009
    MrMark-
    Took the whole stinking thing apart. No blockage, belt is good, cleaned a little debris from brushes, reassembled and still no suction to floor (and brushes are spinning furiously) but great suction at end of hose when disconnected from floor use. I don't know what else to look for. I ran it in all height positions, and it can't even pick up a small bit of paper from the carpet. The only reason it's picking up dog hair is because it sticks in the brushes.
    Trust me, there is no clog. Like I said, I took everything apart from the bottom and above the roller ( as if I were changing the belt). The whole mechanism used for the floor was completely exposed. There is nothing stuck in the throat, which I took completely out (it's a short white tube with a bit of a bend to it), there is nothing between where that lies and the roller. There is nothing in the hose; as I stated before there is great suction at the end of the hose where the attachments fit on, so nothing is clogged between the end of the hose and the vacuum itself. There's not enough dog hair to hinder it in any fashion. If you
    I can assure you it is NOT a clog. I would be happy to show it to you in person if you live around Fort Collins, Colorado. I'm exceptionally mechanically inclined and appliance savvy. I had the entire lower portion of the vacuum taken apart and there is absoloutely nothing to stop airflow. There is enough suction at the hose to have it hold itself to my hand unaided. Additionally, I have the same vacuum in the bagged version, which HAS seen a TON of dog hair pass through it and it still works perfectly after 10 years. I got the bagless one (used) when I separated from my husband, because the other one has performed so well.
    I think the hose is fine and when I have used the attachments, the suction seems to be very good. The first thing I did when I got the vacuum was thoroughly clean the filter and cannister. Can this overload bypass still allow enough suction at the hose for attachments (a much smaller area for air to pass through, thereby concentrating the suction) but not sufficient for the floor head? If that is a possibility, I would have to say that maybe that is the issue. If you would like to email the manual, that would be a great help and I can check that out. Thanks a bunch. Email is sisboldt@hotmail.com
    AB, really? Small world, isn't it? FC is not such a big tourist destination, I would have to assume your travels here were business related... : )
  • Anonymous Feb 24, 2009
    I have good suction on hose, but none below for floor cleaning
    President:
  • 1,214 Answers
Something is stuck in the throat of the floor head, between the brushes that turn, and where the hose connects at one side (usually right hand side) of the floor head.
Reply back what you find.
Posted on Feb 04, 2009
  • 2 more comments
  • Mark Egan Feb 04, 2009
    Look harder. Get a flashlight and look into the port.
    Also take the plate off the bottom as though you were going to change the roller belt (by the way, check the belt while there). You should be able to see all the way to where the hose attaches on top.
    Reply back what you've found.
  • Mark Egan Feb 05, 2009
    Can you see from the brushes all the way through to where the hose connects on the top side of the floor head?
    Take the hose off the floor head.
    Turn the unit over, take the bottom cover off that allows access to the roller and belt. I can't quite see from the exploded views how the air flows toward the back right of the floor nozzle/brush roller assembly, but somehow it get's to where the hose attaches at the top of floor nozzle.
    And you said one key thing in your response. Dog hair. Hair will get caught up in the passageway that is plugged.
    Use a coat hanger or stiff wire if you need to. Plunge it in from the top, and the bottom, to try to dislodge whatever is plugging the passage. Shine a flashlight down the passage from the top. Shine it up the passage from the bottom. Make sure you can see light all the way through.
    Let me know what you find. I can assure you it's a clog in the area I have described, unless there is something in your description that is steering me the wrong way. But I don't think so. THe probelm your having is typical of this style of vacuum.
    Is there a split in the hose by any chance? Or does the hose collapse when connected to the port on the floor head?
    And, is the suction as strong as what you would expect it to be at the end of the hose? That it has suction is very subjective, a little bit of suction is suction, but then a whole lot of suction is suction.
    BTW - Didn't mean to come down so hard with regard to a clog in the floor nozzle. It's just that that is usually where we find the clog or restriction.
    Finally, how clean is the filter?
    Have been to the AB plant there a number of times over the past few years. Too bad I don't have any trips scheduled to come up anytime soon.
    Do you have the manual for this vacuum? I've tracked one down if you want it.
    There is one thing that we have not looked at. It's a spring loaded motor overload bypass, and it could be stuck in the open position. I can explain here, or will email you the manual, which has instructions for fixing.
Do you know why my kenmore vacuum is not picking the dirt up?
there are a couple things that can cause this -- first is a dirty/clogged filter,, remove the filter and tap it out and brush it out with a stiff brush ( a air compressor works best to blow out the filter ) ( but there are some filters out there that are not made of paper and are able to be washed in the dishwasher and dried out and re-used ).
second thing to cause a loss of suction is a blockage in the suction hose -- this blockage is almost always in the hose where it bends slightly down to the floor unit,, remove the floor plate and use a wire coat hanger to fish out the blockage. while you have the plate off make sure you check the belt for wear and tear.
c...
Feb 24, 2011 | Kenmore Progressive Bagless Upright with...
My Kenmore Progressive Canister turns on but there is no suction
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Aug 22, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
I have a Kenmore Progressive Upright Vacuum - Purple, and it worked just fine. I emptied the canister (like always) and put it back in place. I turned on the vacuum to it immediately shutting down (motor)...
Make sure that something didn't fall into the fan assembly in the base when the canister was removed. The motor should have an overload reset switch. Try moving the motor manually (power plug out) to make sure that it isn't bound up.
Dec 24, 2009 | Kenmore Progressive Bagless Upright with...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
I need to take apart my Kenmore Progressive Bagless Upright with Inteli-Clean System
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Jul 29, 2009 | Kenmore Progressive Bagless Upright with...
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk.
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore progressive bagless no suction however brush runs well .
remove all the filters and clean themon the bottom you have what is called an intake hose.you will see it as it comes up from the bottom and up on the backside.it connects to a fitting take the screw out and pull the hose away from the back.take a coat hanger and bend the end so its round then work it down through the intake hose,you should be able to push the clog out through the bottom
Mar 20, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore bagless 339123
take the filters out and clean them.try taking the filters out and turn it on and see if you have suction then.if you do the the problem is the dirty filters.ok if you still have a problem feel free to call ma at 314-628-9153 and i'd be happy to walk you through it.vacuum cleaners are my hobby i clean them up repair the then sell them
Mar 01, 2009 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
325 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
