Question about Texas Instruments TI-86 Calculator
Adjusting the ti-86 screen
I bought a ti-86 graphing calculator from eBay and the screen is shifted to the right by one column and it makes it hard to see if i really did type a (1) or if the 8 is a 3, and so forth. please can somebody help me figure out how to align/adjust the creen on my ti-86 so that i can see all numbers and calculations?
  • 4 Answers
First make sure the cable at the top of the screen is not pealing off near the edge, on the inside of the calcualtor. You may need to peal it off and reattach it, align the strip with the metal coating strips on the glass, you will see the strips when viewing the glass at an angle, but that is risky because you may not be able to reattach it. Next check the small square that says "8" on the back of the display board, you will see minature wires, make sure all the wires are lined up properly, if not thats a factory defect. Goodluck.
Posted on Apr 24, 2009
Where is the insert variable key on my graphing calculator
You can type in an x-variable by pressing the x-var key.
For other graph types, the variables r, theta, t, can be enter by pressing the appropriate function key. from the graph equation entry screen.
May 14, 2014 | Texas Instruments TI-86 Calculator
Ti-86 Error Message--HELP!!
To restore memory on a TI 84 to factory settings follow the directions on pages 108 and 109 of the instructions manual (TI 84 Plus Silver). Otherwise look in the index for RESET MEMORY to get the right page. Be sure you read the precaustions!!!!!!
Dec 12, 2009 | Texas Instruments TI-86 Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
IT-86 Both batteries removed, now dead
Use the TIconnect or TIGraphlink software to reinstall the programs. You will find the programs in the TI Program archives.
Hope it helps
Jan 18, 2009 | Texas Instruments TI-86 Calculator
How do I graph ordered pairs on a TI 86 plus?
Use the stat menu. Enter 1st member of a pair in List1, Enter 2nd member of pair in List2. Graph the data as a scatter plot in stats plots.
Hope it helps.
Jan 15, 2009 | Texas Instruments TI-86 Calculator
TI-86 Calculator Problem
Most likely you're trying to graph a function while you have the stat plot turned on. Turn off the stat plot and try it again.
Oct 16, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
120 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
