Question about Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop
Strange message saying "Warning! Your chassis has been opened!"
This is a new PC - only 3 weeks old. Last night I plugged in some headphones for the first time. A screen came up asking for a password to do this. I thought this weird but carried on anyway. Then a green Acer came up that I didn't understand at all so I clicked it off. Everything was fine. I switched the PC off. Later switched it back on and a black screen came up with loads of gobbledegook on it and a final message at the bottom saying "Warning! Your chassis has been opened!" I never touched it! Nothing has been opened. We telephoned Acer who didn't seem to be able to help (what he was indicating should be on the screen wasn't) and accused us of opening the chassis. My husband fiddled around later and came across a screen which asked if we wanted to save recent changes. He indicated no and up came the sign on screen. We signed on and away we went. However, the sign on screen now appears to indicate that there is more than one user on the PC which is not the case as my husband and I use the same sign-in. The PC is OK as long as we keep it in sleep mode but if we turn it off, we have the same screen come back up saying about the chassis so he has to go through the process of trying to sort it out. Anyone out there any ideas except for sending it back as suggested by the Acer guy?
  • 2 more comments
  • vivversis Feb 06, 2009
    Thanks so much for your time. I suspected we might have to return it but was really hoping not to have to, since we've spent so much time downloading all our stuff to it and finally getting on broadband. Time to box it up then.....................
  • vivversis Feb 07, 2009
    Thanks again
  • BODUNK May 04, 2009
    I CONTACTED ACER AND THEY SAID I NEED TO CLOSE MY DESTOP CHASSIS. I DONT KNOW WHAT THAT IS.
  • Anonymous May 21, 2009
  1. Hit DEL when booting to get into the BIOS
  2. Choose PC Health function
  3. The first item is the chassis open function - hit Enter to change it to Clear.
  4. F10 to exit and save the change
  5. Reboot
  6. GO into the BIOS again and this time select Disable for the chassis opened function
  7. F10 to save and exit
  8. Done.
Posted on Oct 13, 2009
I had the same problem with an Acer desktop after I upgraded the Ram, and I tried everything including resetting the bios. I finally solve it by entering the bios and Loading the Optimal Defaults and then saving it with F10. I have not had any chassis intrution message since then
Posted on Oct 07, 2009
    Scholar:
  • 116 Answers
It sound to me like there is an issue with the BIOS.
This can be caused by
1. Corrupt BIOS (resolve by updating BIOS from Acer - but there is not one on the download page)
2. Loose CMOS battery (You would need to pop it open to reseat it)
3. Bad motherboard - have it serviced (warranty) or return it and buy a new one (the Acer guy seems to suspect this, and i would take the opportunity to return it if still possible)
just my $0.02
Posted on Feb 04, 2009
  • Ron
    Ron Feb 06, 2009
    You could use the built in Easy File and Transfer wizard to save your settings, and move your files. You would still need to install any programs that you've installed. (you can save on external drive, network, or optical drive)
    Here is Microsoft site that discusses how to do this. (It does not always work as nicely as they say, but it can be a timesaver when it does).
    Too bad about the time spent, most failures happen (any brand) early in the life of the computer when there are faulty parts. If it was anything other than the mainboard, it might be worthwhile replacing the defective part. Better to replace it now, then to deal with it when the warranty expires.
    I hope you have better luck with the new computer.
  • Ron
    Ron Feb 06, 2009
    Here the Easy Transfer web page I forgot to add
2010 Mazda 3 power steering quit warning light is on
Could be the power steering pump is bad.
Dec 06, 2014 | 2010 Mazda MAZDA6
I have a HP Compaq DX2000MT computer. When I want to start up the pc, he gives 10 beeps and the following message : Chassis fan not functioning, check fan connections & call for service. Shutting...
Without the chassis fan the pc would overheat and fry so it's shut down. Do what the warning message says: open the case, clean the interior and check the wire connector of the fan. If the fan still doesn't turns then it has failed and it will have to be replaced - a new one costs$10 at every pc shop.
You will need the manuals for service and maintenance
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=401819
Aug 07, 2011 | HP Compaq dx2000 Microtower PC Desktop
Brookstone wireless headphones have static along w/ tv sound
Well I just plugged into the cable box and that worked. On my old tv as well as my newer one the only audio out was an optical I had bought an optical splitter (one input for my sound bar and the other one to the optical to Rca) and an optical to rca for the headphones. This allowed me to use the headphones on all things going through the tv. For some strange reason it no longer works that way (just got my new tv this week). I bought all pieces on Amazon for a nominal cost. I'm going to doublecheck all connections again tomorrow.
Jul 12, 2010 | Brookstone Surround Sound Earbuds...
C4280 photosmart printer - printer screen says "Printer cartridge missing or not detected" - I replaced the old HP cartridge that was in when the message appeared with a new HP printer cartridge in but it...
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Apr 01, 2010 | HP Photosmart C4280 All-in-One InkJet...
Suspension fault message on my jaguar xjr (1999)
I HAVE RESOLVE THE PROBLEM BY REPLACE WITH A NEW ORIGINAL STRUTS W/OUT HYDRAULIC SISTEM ON THIS MODEL (94-99)
Apr 10, 2009 | Jaguar XJR Cars & Trucks
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Open Questions:
Acer Veriton M460 Quad won't start after running Vista Scheduler I have a new Acer Veriton M460 Core2 Quad PC running Vista Business. Something weird is happening that seem to be related to the Vista Task Scheduler. I have a complex chain of actions that start from one action. The chain is: run software to download .html files, run Microsoft software, run DOS batch files and DOS executables. It works fine if I start it from the desktop and if I start it using Task Scheduler. However, if I used Task Scheduler, the next time I boot up the PC it freezes at the Acer pre-Windows boot screen. Even the set up keys mentioned on that screen don't work, e.g. "press F12 to choose a start up mode". I have to pull out the power plug. When I plug the power back in, even after quite some time, the PC proceeds with the boot up successfully through to Windows without me having pressed the Power On button on the computer. So the bottom line is that if I use the Scheduler, my PC won't start the next time I go to use it. There was an event that may have some relevance or could be coincidence: about a week ago after I first scheduled the task I came back to my PC, which had run my scheduled task unattended after waking itself from Sleep Mode. I found it showing not Windows but the PC boot options menu. I pressed the highlighted option, which I think was Normal. This hasn't happened since but could be related. Incidentally, my PC was supplied with Sleep Mode set to start after 20 minutes plus there is a screen saver. But neither was going when I last used the scheduler for my task. Any ideas?
Feb 28, 2017 | Acer Veriton M460 Micro Tower Core 2 DUO...
Acer Veriton M460 Micro Tower Core 2 DUO E4500 2.2GHz Dvdr GigaBit Ethernet Wvb VM460UD4501 PC Desktop Logo
7,652 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
