Question about Samsung TXN2745FP 27" TV
Samsung TXN2771HFX 27" TV
The TV has a strange powering off issue. It seems the longer the TV is unplugged, then when you plug it back it, the TV will work. I can only get about 4hours of use before the tv turns it self off. And to get 4 hours I have to have it unplugged for a couple of days. If it is plugged in and I attempt to use it every day then it will last 5mins to an hour before shutting off. Is there an easy fix to this problem? I have tried using fans to blow on the back of the tv, thinking it may be an over heating issue, but this has not effect. What are my options besides drop kicking it into the nearest land fill?
  • 3 Answers
Too bad I didn't see this post earlier...it's probably OBE by now. Still, your problem is most likely a bad capacitor in the power supply. If you know your way around a circuit board, you can probably find the bad cap via visual inspection (bulging top, leaking electrolyte, etc.), and can replace it yourself.
NOTE: TVs have numerous high-voltage circuits, and large capacitors can retain dangerous charges for a long time after the electrical source is disconnected. DO NOT work on your TV unless you have the knowledge and skills to do so safely!! Otherwise, take it to a TV repair shop--this is a trivial repair for them, and it probably won't be too expensive.
Posted on Sep 08, 2010
Display on control panel no longer displays.
Surge associated with power outage can make disasters in refrigerators. You need a power protector for refrigerators.
Now, what already is damaged, should be repaired by an authorized techician.
For protector, you can do a search; typical return is this one
Electronic Surge Protector for Refrigerators up to 27 Cuft and Freezers
May 13, 2015 | Samsung RS277AC (27 cu. ft.) Side by Side...
Proscan 27" tv
if you want to eliminate magnetism, you have to degauss the screen, if you don't know how to do that, here is a small guide for that: http://www.wikihow.com/Degauss-a-Computer-Monitor
but that strange shutting down its the transistor... so your best choice is to send it to a repairman to change the transistor..
if you try to do that for your self, you could even get shocked with the electricity contained in the tv... even if its turned off and unplugged..
Dec 22, 2007 | Proscan PS27500 27" TV
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Tv turn on and oof by self
Try unplugging the tv at the wall outlet or from power bar, for a count of ten then plug back in, should reset tv.
Hope this was helpful
Apr 19, 2014 | Samsung P2770FH 27 LCD Monitor 1 ms 1609...
When the power is turned on, the screen stays black (nothing is displayed-totally dead). Then it won't turn back off unless I unplug it. The model is DX-LCD37. It doesn't matter if I use the pannel...
Had a very similar problem with mine - not sure if this will help or not, but it seems to be doing the trick (channels scanning as I type).
I unplugged the tv for about an hour. I unplugged the cable, and all the components. Then I turned the tv on, and was able to get to the menu screen. Previously, I couldn't change channels or even power off from the buttons on the side of the unit either...
Once there, I plugged the coaxial cable directly into the side of the set, then ran the auto-scan.
I know it's not a techincal answer, and a bit strange, but as I mentioned, it seems to be working for my issue.
Nov 26, 2010 | Dynex DX-LCD37 TV
Tv will not turn on unless I unplug it and plug it back in
Here's the fix, it'll take less than an hour if you take a 30 minute coffee break while doing it: http://www.fixya.com/support/t778853-tv_lcd_akai it'll cost $5.00 in parts from The Shack.
Aug 28, 2009 | Akai LCT2785TA 27 in. LCD Television
Akai LCT2701AD - 27' LCD TV/DVD Player Combo
I don't know if I solved the problem. I find though if I turn the TV off and unplug it and then plug back in when I want to watch it - it works. I don't know why but it does. My remote still does not connect to the LCD but I have cable HDTV so chanel changes work from that control.
I am pretty ********** that it is only a year old and this has happened but what can you do? We live in a disposable world.
I was trying to get to your Premium assistance Plan from where I wrote my issue but I don't know where to pay or what to do on your site it keeps taking me all over.
Mar 15, 2008 | Akai LCT2715 27 in. LCD Television
Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
Dec 10, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung DLP TV Powers Off by Itself
yes i have the same problem i need help
Aug 31, 2007 | Proton MM2701VT 27" TV
Samsung TXN2745FP 27" TV Logo
74 people viewed this question
Henry  Thomas
Henry Thomas
