Question about Hotpoint Aquarius WMA42 Front Load Washer
Machine do not take detergent from the dispenser at all
I have wf541 hotpoint and washing maching does not take detergent from the dispenser at all. please help me to resolve the matter. Additionally, prewash butten start flashing.
thanks-ashfaq
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
That sounds to me like a water pressure problem. check the hoses aren't kinked and that water comes out at a reasonable rate.
the small filters where they attach to the machine may be limescaled up and want cleaning.
Posted on Feb 12, 2009
Hi I have a hotpoint aquarius wf541 washing machine that will not turn by hand or any thing can any one help me pls
It sounds like a seriously seized bearing which will need replacing, was it a noisy machine before it went wrong I wonder?
May 14, 2016 | Hotpoint Washing Machines
Detergent dispenser drawer leaks.
give the draw a good clean by pulling it out, and check the level of the machine
Mar 15, 2014 | Hotpoint Washing Machines
My wf541 leaks from the soap dispenser drawer when water is being put into the machine
Reduce the water pressure, I assume its too high , also make sure no partial blockage at dispenser hose ..try pouring in a jug of water and see if it goes away Freely...Good luck
Feb 04, 2011 | Hotpoint Aquarius WF000 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Flashing lights
HI, this is a control fault that may be corrected by unplugging or shutting down the breaker switch for about five minutes. this will reset the microcomputer to its original state. after the five minute reset, plug or switch the machine on and observe the results.
If the unit is still blinking and the unit is not operational, this will confirm a major control fault and you will need to replace the control board(microcomputer/timer control)
May 18, 2009 | Ariston Technologies Washing Machines
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wf541 model
The sypon tube needs cleaning, you need to poke it clear with something, the tube is part of the dispenser , thouroughly clean every part.
Sep 06, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
214 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
