Question about Bosch Drills
BOSH PSB 600 RES drill will not restart
i have a bosh psb 600 res drill and all of sudden now when i try to use it stops after a few seconds. then it will take another day before i try again and somehow make it work - but guess what it starts but a few seconds it stops again.
it is a relative new drill, there is no smell of burning or overheating..
any advice would be helpful. thanks
  • aclym Feb 06, 2009
    thanks for the advise
  • 257 Answers
Hi, Sounds like you have a pinched wire somewhere. When you say you somehow make it work are you bending the powercord, shaking the drill or what? Any of those things would suggest a pinched wire or broken switch. Make sure the switches for reverse and hammer work in both directions. You say it is relatively new and there is no smell so I would not suspect the brushes and it doesn,t sound like it is running long enough to overheat anyway. The best advice I can give you is that the drill needs to be opened and examined, and if you have an ohm meter check all of the connections from the power cord to the trigger. If you don't feel comfortable with that then you may want to return it under your warranty or you may want to do that anyway. Good Luck!
Posted on Feb 05, 2009
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
Why is my bosh drill stoping and starting
needs brush cleaning when the brushes in the motor get a little dirty they tend to work intermittently
Jan 15, 2015 | Bosch Drills
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222 evs
Push the red button all the way in as far as it goes and turn the knob to the left (counter clockwise) past it's normal position. Then you can pull the knob out. When you replace it make sure that the pin part fits inside the slot of the shifting arm inside the tool.
Aug 07, 2012 | Bosch Drills
Bosh 24v sds battery problems
Have you tried charging and discharging the battery a few times, sometimes that helps build up the charge.
May 31, 2012 | Drills
My Bosch 24v PSB 24 VE-2 has suddenly stopped working. The battery charges ok but when fitted into the drill , the drill makes a faint whining noise but fails to work. Any ideas ?
Hello
The motor windings in the drill are bad or have a bad connection.You may also try cleaning the battery contact points with a pencil eraser.
Jun 25, 2011 | Bosch Drills
Drill keeps on stopping and won't restart
Check the cord...sometimes if the brushes are not seated well or if there is a cut in the cord you will run into that problem....If it is not that then possibly you just have a faulty drill
Jan 04, 2009 | Drills
Drills Logo
310 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
