Question about Sony Playstation 3 (PS3) Console
I have no computer or cable and need to set up internet on my PS3
I ordered internet service from AT&T and they sent me a wired modem. I have no computer or cable and got internet soley for my PS3. My PS3 is in my living room and there is not a working phone jack for the ethernet cord. So, I need to hook my modem up in my bedroom and keep my PS3 in my living room. I have a wired modem and was told I needed a wireless router to fix this problem. Well I bought one but I can not figure out how to hook it all up. Is it even possible to hook a wired modem to a wireless router? Does something have to go into the back of my PS3 or when I hook the router and modem up will the PS3 just pick up the signal? Am I making sense? I am clueless to this. I did not even know what a modem or router was until a few days ago and not even sure I know what it is now. Please help.
  • Michael Fisher
    Michael Fisher May 11, 2010
    A Router Will Replace Your Modem
Next time just google:"how to plug in wireless router"
Your router should have come with instructions on a CD. I have to suggest following the instructions of the CD.
The modem needs to be plugged into the wall by phone cable (not same thing as Ethernet). After plugged to power and the wall you should see lights turn on, probably green. The modem should have an Ethernet jack, you plug in the Ethernet cable to the modem and the router in the odd slot out. If plugged in to power and the modem you should see more green lights.
Without a computer you can't password protect your wireless signal so anyone can join your network and slow down your access to the internet, not to mention a lot of other things.
Posted on Feb 04, 2009
    President:
  • Sony Master
  • 1,314 Answers
??? A router will NOT replace your modem; the router won't work without the modem. If you're going to give advice, please make sure it is somewhat correct.
Okay. So first you need the telephone cord to go from the phone jack into the DSL port on your modem. Then you need the Ethernet cable that came with your modem (looks like a phone cord but much bigger) to go from the ethernet port in the back of the modem into the wan or internet port on the router. Verify that the DSL and internet lights are on on the modem.
For the rest of the setup, watch this . It will walk you step by step in connecting your PS3 to the wireless internet. Thanks and please take a moment to rate as fixya.
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
Can't get online to play this new PS3. The console is hooked up to the TV & Belkin Wireless router. The internet, computer and phone line are in a different room and can't reach to hookup. AT&T is...
There should be no HDMI cable to router. In any situation.
Try the following:
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and choose the appropriate settings. (What's highlighted is going to be the best option, continue to hit the right button on the analog to go through the stages.)
Be sure to choose "Wireless" when configuring the settings if you are using wi fi for connectivity.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Can i hook up my ps3 to a wired internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
Cant find IP on hardwired PS3
is that modem setup to a computer before hand? you need it to be programed with a computer then after you access the internet, then hook up the modem to the ps3,
if you bought a new modem then you need to call your provider and have them program it
Jan 30, 2010 | Sony Playstation 3 (PS3) Console
Cant get wired internet on my ps3
A cable modem & a router are two different things. You can pick up a "Cisco 'EtherFast' cable/DSL" (wired or wireless) router at Wal Mart for $35. But you need both a modem & router to get your PS3 up & running on the web. Once you get on, you'll need to set up a "PlayStation" account. Unlike the Xbox 360 Live network, PlayStation is free of charge. It's a very user-friendly interface, so you shouldn't have any problems there. Cisco will give you live customer service to walk you through hooking up your router. Please let me know you make out. If I can be of further assistance, please let me know. Good luck, bro.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Can it be done?
All of the ps3 models support wired and wireless internet. All you need is high speed internet service, and a router (wireless router if you want wireless internet o.~) you plug the router into your high speed modem via ethernet cable. then you plug your computer and ps3 into the router with ethernet cables. your good to go! if you want wireless for your ps3 you need to use the wireless setup on the ps3. your done :)
Hope this helps.
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Trying to get internet connection on my ps3
I once had the same problem. What i did is that i booted the modem and the Ps3 (turned both off) and then turned them on. Then i went to the internet settings on the Ps3 and tried the internet connection check and it worked! I hope you have some help of this.
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
The ps3 wifi is very finicky --
While the ps3 scans for a hotspot turn the router off then on so the router aquires the ps3.
Goto settings
Goto network settings
Goto network connection, select enable
Goto Internet connection settings just below internet connection-
Push yes when it says you may be disconnected
Select wired or wireless
For wireless use scan or enter manually
Follow on screen instructions.
Once that is set up return to main menu and go to network near the right
Then once in the internet browser press triangle and goto file and enter the internet address you would like visit.
If all else fail use the ethernet cable to attach it to your laptop. Then run network setup on the laptop and add the ps3.
Nov 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
