Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
Recovery tank not filling
Hoover working, dispenses from upper tank into carpet but water doesn't enter recovery tank. Is there a jam in the automatic shut off so that water cannot be recovered?
  • 1 more comment
  • Anonymous Feb 14, 2009
    It seems like the suction around the cover is not holding correctly. May need a new seal or cover?
  • zuckers420 Mar 04, 2009
    I'm having the same problem with my recovery tank. The water solution is coming out but as soon as I turn on the cleaner the red shutoff float pops up to the top and shuts off the suction. I've cleaned the tankand filter around the shutoff float and it's still not working. :(
  • Anonymous Apr 04, 2009
    This is annoying and needs to get corrected or we all need to get new steam vacuums!
    Problem Solver:
  • 17 Answers
The tank has an automatic shutoff float (red) that will stop the suction if the water level gets too high. this can also happen if the tank is not level or clean as the float can bounce around and jam at the top. I've actually had this one happen). I would make sure the float is down during the cleaning and see if the suction comes back. if not, please provide more details and we'll get 'er fixed!
Posted on Feb 04, 2009
My Hoover Steamvac Widepath will NOT pickup the water after dispensing. I checked the hose inside the cleaner, there was a cut in the hose so I put electrical tape and completely sealed the cut. Still...
Hi, empty the recovery tank of the Hoover SteamVac if the cleaner fails to pick up dirt. Once the tank is full, many Hoover models have an automatic shutoff that stops the cleaner. If the does not resolve the pickup issue, check the hose of the machine and remove any blockage.
Examine the water tank if water does not dispense from the SteamVac. It could be empty and need of a refill, or you may not have locked the dispenser firmly in place. The detergent tank should also be looked at and filled if empty.
Take care
Apr 12, 2010 | Hoover F6213-900 SteamVac Agility...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
How does lower and upper buckets work . is it the dirty water suppose to go in lower bucket or what . as i am trying to use this vac i am not able to
The Upper tank is for hot, clean water, with carpet cleaning solution mixed in at 5 ounces/gallon.
The Lower tank is the dirty water ecovery tank, hooked to the nozzle on the hood to **** up the water from the carpet.
Jan 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac clean surge
The recovery tank lid isn't locked down all of the way around. The foam filter on the inside of the tank lid is up too far, needs at leasat a 1/4 in gap from the top. The filter screen by thye indicator is clogged. Some have a duct that sits in front of the recovery tank, either it isn't there or not pushed down all of the way.
May 14, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
414 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
