Question about E-Machines eMachines Desktop PC
Desktop ( Emachines 210 ) Very slow ? Ran via win xp proffesional
I've got a desktop computer Emachines 210 2.3 GHZ 80GB HDD .
The computer takes around 1 minute to get to the desktop and then around 10 minutes minimum to load all application's usually msn messenger ZA pro intel extreme graphics and a few others , i noticed there are alot of procesers running but not as many as my laptop and that goes around 3x as fast as this computer and has got less memory and runs by windows xp also ? The computer is particularly slow when trying to open internet explorer and sometimes right click on the desktop! i thought of reformatting Hdd but not sure? any advice will be appreciated , please try to be specific when you answer Thanks.
    President:
  • 1,179 Answers
Try going to the control panel>performance and maintenance>disk cleanup. After running cleanup run the defrag. You can also cleanup your internet browser by deleting cookies, temp internet files, & browsing history. See if this helps speed up the system. Hope this helps & please rate this solution fixya. Thanks.
Posted on Feb 04, 2009
Couldn't find audio driver for IBM thinkcentre MT-M 8327-77G for windows 7
That because this system came XP. You will need to run drivers on compatibility mode if possible.
Oct 09, 2012 | IBM ThinkCentre 8172 Intel Desktop PC -...
Sir i want to check our lenovo 3000 that it contains correct RAM,HDD and everything in it. and another problem is that i have os win 7 proffesional so that i am not able to install c language in it.
Yes it looks like it, to run the C language you will need to dual boot Windows 7 and Windows XP. Or install only WIndows XP. Another idea is to install a Virtual Windows XP Operating system. Therefore XP running in a Window of Windows 7. Called virtualization.
However virtualization is not possible on this model of Intel CPU.
Take care!
damnor01
May 28, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
My machine seems to slow down alot what can I do to fix this?
Delete the temporary files form the computer. To do so Click Start-> Run-> type %temp%-> hit enter. Select everything and delete it.
Same way delete the temporary files from windows well. Click My computer-> Local Disk-> Windows-> temp
Also delete prefatch under windows. ClickMy computer-> Local Disk-> Windows-> prefatch.
Try to restart your computer everyday and not just log it off.
Try and see if this works.
Jul 02, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
A copy of win xp disk
if by make, you mean copy then yeah. you can copy an xp cp under vista using a burning software that works comfortably with vista.
Sep 24, 2009 | Famous Brand Dell Optiplex GX280 Intel...
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
How to move contents from computer default hard drive to external iOmega hard drive, to make computer faster
There is a program on the xp cd called Fastwiz- it will save all your profile data for you. Unfortunately it's REALLY slow and you would be better doing it by hand. If you want to do it by hand you will need to copy all the data in the Documents and settings folder for all the profiles, plus any other data that you will need to reload the drivers. I recommend saving the e-machines drivers directory.
Wiping and reloading the operating system is the best way to resolve problems with a slow system, and a faster bigger newer hard drive is a good idea too. E-machines have a tendency to just die after a year- be aware that you get what you pay for. Also adding more ram to this system will help too.
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
E-Machines eMachines Desktop PC Logo
405 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
