Question about Hotpoint Aquarius WMA42 Front Load Washer
Wont get rid of the waste water
Wont empty the waste and the lights flash on the front of the washing machine
Try removing the pump from the rubber hoses, and open same , as its probably clogged with debris,, ie coins etc , if pump is cleared, and its still not working,, buy a new pump, hope this helps you
Posted on Feb 04, 2009
  • 112 Answers
Have you checked the drain pump ??????
Hotpoint WML540 gets to spin then stops wont empty and all lights start flashing
hi sharon, i had simular problem, if your waste outlet from your machine to kitchen sink is pushed on to sink waste sometimes held with jubilee clip, disconnect it and check weather its clear cos it can get build up of ****** and stop water from draining, hope this helps.
Jul 08, 2012 | Hotpoint Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
I have an indesit wil133 .when one wash finished,the red flashing light came on ,so i could open the door,but also the delay timer & stain remover lights were flashing. now when i try to put another...
I would go to the manufactures website and download the user guide and look in the trouble shooting guide or I would check the water pump to see f there's not an obstruction in the pump preventing the pump from emptying the drum completely as if the water sensor is not telling the machine its empty therefore it cant start again
Jan 17, 2018 | Indesit W 123 Front Load Washer
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
Hi, we have an Indesit WIXL 143(UK)washing machine. Both the stain remove and easy iron lights flash together about twice per second and the door lock light flashes faster on doing any wash. Is this a...
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Nov 02, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
143 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
