Question about Apple MacBook Mac Notebook
Dirty or damaged disc error message
For every disc inserted, dvd player spins and hums a little and then displays "dirty or damaged disc" alert message on tv screen, while the dvd player displays "disc error." I do not have a manual as this player was given to me without one. please help.
  • 23 Answers
Is this a question about a mac laptop or a normal dvd player connected to a tv,because the way this is worded,it seems this is listed in the wrong category. The answer above was based on this being a mac laptop.If it actually is,then new drives are cheap on ebay, but if it is just a normal dvd player, just go to walmart and get a cheap one,they have one for $18.88 right now where I live, I'm sure they have something similar by you.
Posted on Feb 08, 2009
    Sniper:
  • 57 Answers
Hi there im sorry to tell you but inless you have used an dvd/cd cleaner inside the disk drive and it hasent worked after the clean your looking at drive failure this happens to every laser product at some point with age or wear, there are many sites that sell replacement dvd drives and there not to expencive and quite easy to replace with normaly one screw holding it in place under a push plate at the bottom of the laptop. if you need help locating a drive ill be happy to help you look for one please leave details of make model ect on here and i will help you look many thanks
Posted on Feb 04, 2009
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
When I insert a disc I get a "Disc Error" after
Most DVD players display that kind of error when unable to read data on you disc media. Try other DVD disc if that post the same problem. A new one will test if it is the unit problem or the media disc problem. If it post the same problem on a disc that runs well on other players then your player probably has a dirty lens. You can clean the lens using commercially available DVD lens cleaner on the market.
Jun 14, 2011 | LG DP450 Portable DVDDivX Player
Wat should i do when is displays no disc
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Jul 23, 2009 | Panasonic PV-20DF64 20 in. TV/DVD Combo
READS "NO DISC."
the laser is urnt out or damaged or dirty.
try putting a laser cleaning disc in 1st in this does not work then the laser is damaged or burnt out.
you may be able to take .it in for repair
Apr 26, 2009 | Philips DVP642 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
Disc Error/no disc messages
there is a strip that connects from the body of the lens to the circuit board take it off and replace it this will fix your problem you can contact dalbani in miami florida.to purchase the strip
Feb 17, 2007 | NAD T512 CD Player
Apple MacBook Mac Notebook Logo
138 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
