Question about Kenwood KDC-MP528 CD Player
I haveA GoodmansRadio/cassettModelNo.GCE572RDS
I am trying to sought out the wires,on this radio,so as to get it to work in a Landrover-Freelander1999 Reg,which has a Radio/cassett standard Model
R660. THe reason,I want the Goodman to work,is I also have A 6.C/D player
Box,to fit with it,So,would like to obtain a wireing handbook or any INFo
to get it to work.I can get it to light up when switched on.I have all the speaker wires marked, So,it is the remaining wirers
Hi, the other wires are:
Orange - Permanent +12v
Orange/White - electric arial
Red - 12v Ignition Switch
Black - Ground (-ve)
Hope this helps
Brookers
Posted on May 13, 2009
I HAVE LOST RADIO CODE FOR MY LANDROVER FREELANDER HOW CAN I GET IT ?
the only easy way is you can go to a landrover dealer for help there are people that can decode radios but i have found franchise dealers more helpfull and less expensive
Feb 27, 2017 | Land Rover Freelander Cars & Trucks
I have a 'Eurovox' car radio/cassette with 'Land Rover' on the front, but the two plugs do not match up with my Range Rover. So I would like to know how to, (after removing the plugs), wire it in. These...
If you leave the original plugs connected to the radio unit you will be able to get an adapter from a motor store. In the UK Halfords keep most types, in the US I don't know what similar stores you have but i would imagine Radio Shack or similar will keep the type you need. Take the radio unit with you so they can see the connectors on the unit - they will probablky be ISO fittings and then they will be able to advise the Range Rover fitting.
If they do not have a suitable adaptor, ask them to identifiy the connectors on the radio unit (DIN, ISO etc) and then ask your local Landrover/Range Rover dealer if they can supply an adaptor for you.
Hope this clears your problem, please mark the post as Fixya.
Sep 24, 2008 | Car Audio & Video
2005 landrover lr3 radio won't switch from bluetooth to cd or fm radio
try a hard reset by disconnecting the vehicle battery for a minute or two then reconect there is no need for a radio code on lr3 if this doesnt work ask your local dealer to plug the car in to there diagnostic equipment and update the radio software
Oct 26, 2010 | 2006 Land Rover LR3
I have the stereo wired up in my 1995 landrover discovery , evrything seems to be working , plays cds , picks up radio stations but there is absolutly no sound . The only thing not connected is the rca's...
Sound like the Eurovox unit. Regardless, determine the make and model number of the radio/CD unit and do a GOOGLE search for that unit.
I don't remember the site but there are several that will supply a wiring diagram for that model. You already know you can spend hours trying to find a fault like that one - a specialist installer (NOT a Land Rover dealer) will probably fix it for less than $50
Jun 28, 2017 | 1995 Land Rover Discovery
Need radio code for 1999 landrover discovery 1
Can you confirm what brand the stereo is? If it is the Visteon brand that Landrover fit then I can help. Just let me know.
Thanks.
Apr 03, 2010 | 1999 Land Rover Discovery
2004 almera radio/cd combination gave up.have removed console cover to check all seems to be ok and audio fuse is ok
You have two wires that are needed to turn the radio on. The positive and the ground. Check for 12volts on the red . If you have 12volts and the blk is hooked up then the radio is the problem. All the other wires are for speakers and the antenna motor if you havea retractable one. If you dont have power on the red or you dont have a red wire test them all. You should have 12 volts on one wire with the key off. This is memory. You should have 12v on two wires with the key on. This is memory and power.
Jan 14, 2010 | Car Audio & Video
I havea buick riviera and i disconect the radio
Check the code on the computer first then check the fuses.
Aug 05, 2009 | Vehicle Parts & Accessories
Installed Jensen radio in 1996 Landrover Discovery. Radio has power but no sound. Could the wiring be the problem? I've tried everything and still no sound.
if you tried everything still nothing then try different radio sometime ac for the sound inside the radil is bad you wont get anysound
Jul 21, 2009 | Car Audio & Video
Ihave a 1996 landrover discovery 2 audio problem
its the capasator needs replacing you blew it up.
Mar 26, 2009 | 1996 Land Rover Discovery
Kenwood KDC-MP528 CD Player Logo
108 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
