Question about Sharp Office Equipment & Supplies
AR200 with L6 fault
Sharp AR 200 copier with a L6 fault
    Problem Solver:
  • 14 Answers
Your laser unit may be bad. try c interupt 0 interupt,,enter 14 and push start. the machine should reset. If the code returns, you need a laser unit replaced. 200-300 dollar repair.
Posted on May 01, 2009
  • 4 Answers
Main motor lock detection
Detail When the main motor encoder pulse is not
detected for 100 msec.
Cause Main motor unit abnormality
Improper connection or disconnection the main
motor and the harness.
MCU PWB abnormality
Check
and
remedy
Use TC 25-01 to check the main motor
operations.
Check connection of the main motor harness/
connector.
Replace the main motor.
Replace the MCU PWB.
Posted on Feb 05, 2009
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Part Number of laser diode (Mitsubishi), Sharp Copier AR-M160.
L6 code means the motor is not working. You need to replace that, which means replacing the entire laser module. They can be gotten cheaper used from your local sharp dealer. I know this because I work on these things every day, being a certified sharp tech. L6 code means motor lock or motor sense dead, not necessarily laser dead.
May 25, 2010 | Sharp (SHRAM900) All-In-One Laser Printer
ERROR L6
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Oct 01, 2009 | Sharp AR-M205 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
Jun 11, 2009 | Sharp AR-M205 Copier
Sharp copier
If there is something wrong with the sensors it can be related to the cover as well.
If you turn the power off and back on again. Does the messsage still appear after that?
Aug 12, 2008 | Office Equipment & Supplies
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
314 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
