Question about Janome Memory Craft 10000
Bobbin problems I have trouble with the removable bobbin case on my Janome 10000. During the stitching process, the bobbin case shifts and jumps casing the thread to clump up like a birds nest or jams the needle. What is the problem?
  • ipaulick May 21, 2009
    I have the same problem except I just got done sewing something and it just started acting up. I took the bobbin case apart and cleaned it out and then tried again and this time it broke the needle - inserted a new needle and tried it again and it is still jamming up - I took the bobbin case apart about 5 times trying different things - I can't sew anything now and am very frustrated.... The screen gives me a message to rethreat the needle when it gets jammed up
    Problem Solver:
  • 5 Answers
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
My bobbin keeps jumping up and down in my Janome Platinum 760 and the stitched aren't being formed. Also noisy. Have cleaned out bobbin case etc.
hi have you replaced the bits back in the same way as if fitted upside down or back to front will cause jumping and missing stitches also make sure the bobbin it fitted in it case the shape of 9 if not it will not sew properly hope this helps
Jan 02, 2018 | Janome Sewing Machines
Why is it not stitching correctly?
Rethread your machine completely - I also wind another bobbin
making sure my bobbin is consistent - change needles, make sure
the same thread that is on top is the same thread on the bottom
(same brand, weight etc) and I clean it really good if I still
have trouble with it- that usually does the trick.
Jan 29, 2015 | Janome Memory Craft 10000
Janome 6260 bobbin case sucks in fabric
try getting a new bobbin case
and use a different bobbin
change the needle
if these suggestions don't help then take the machine to a different
repair shop to have the machine checked
Jan 20, 2013 | Janome 6260QC Computerized Sewing Machine
Bobbin jumping
Check your bobbin for burrs, if you find any gently sand with fine grit sand paper.
Oct 25, 2012 | Janome Memory Craft 10000
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Janome 10000 bobbin case problems
make sure you hold the cotton so it doesn't go under and ball up
Feb 03, 2009 | Janome Memory Craft 10000
Sewing Machines Logo
625 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
