Question about RCA Televison & Video
RCA projection tv is blue and fuzzy
Hello, I have a 46" RCA projection tv that has a really blue screen and blurry. Can I just clean the mirrors or lens and will that fix it or do I need a new projection lamp. Does RCA have just one lamp or are there red, green and blue projection guns also
    Problem Solver:
  • 7 Answers
May be convegence try turning down the blue screen and see that that does see if the picture clears...
Posted on Feb 04, 2009
  • mottsy Feb 04, 2009
    yes there are red green and blue bulbs.
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Can I clean the color bulbs on my 52'' RCA television?
To clean these lenses is easy with a clean soft cotton cloth in a kindly way. BUT wait a minute: To get access to those lenses is the really hard job. something as you want to see the core of an onion but tobe there you have to take a cover at the time. Trust me: Literally. Step by Step, at least 40 screws. the front screen is the last step, and then you can see those lenses. If the tv is working OK and is the only job needed, ask a technician for a regular cleanning and adjustment you can get surprised about the service cost (NOT REALLY HIGH i mean). make sure he cleans the back mirror also.
Apr 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
My panasonic big screen screen has shadows and fuzzy picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
RCA HD52W59
Actually, we didn't remove any bulbs, we removed the lamp in the back of the tv.
Dec 14, 2008 | RCA HD52W59 HDTV Projection Television
52" RCA HDTV projection TV 4 years old and just started getting
This unit needs repair your convergence needs alignment, which with the RCA model needs to be done by a tech and the Blue card is either dead or is dying. You need to take it in and evaluate weather or not it is worth repairing or just wpending the money on a new T.V. - You can expect to pay around $350 - $800 to get this repaired, plus pick up and drop off. I would not endevor to do this myself as there are other things that can be damaged when messing with it.
Dec 08, 2008 | RCA D52W23 52" HDTV CRT TV
Strong red tint and a blurry screen
This is a serviceman only job.  It isn't worth it.  The parts and labor are at least $500.
Sep 15, 2008 | RCA P46924 46" Rear Projection Television
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
RCA 46" Rear Projection TV - Picture is Blurry and RED
That sounds like the screen and focus controls you are adjusting. It sounds like you have a bad HV Splitter inside the TV. #205064 or #204809 Depending on your model number. http://www.matelectronics.com/acatalog/Mat_Electronics_Replacement_Parts___TV_134.html sells them for about 20 bucks.
Dec 27, 2006 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
208 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
