Question about Epson Stylus Photo RX500 Printer
My Epson Stylus Photo RX500 won't turn on
1. When I pressed the ON button and it did not light up...
2. the carriage under the glass is in the middleI
I unplugged the printer from the outlet and the computer but it does not help. Please help me
  • 1 more comment
  • Anonymous Mar 03, 2009
    RX500 won't turn on. I have unplugged it, gone through the computer an it will not light up.
    What can I do?
  • Anonymous Apr 18, 2009
    Same thing, he just doesn't do anything when pushing the power on button.
  • kjenor May 14, 2009
    I have the same problem. The printer wont turn on and the carriage under the glass is in the middle. I got no warning ahead and it seems impossible to fix. HEEElp
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Posted on Apr 29, 2009
vkyhunk
  • 156 Answers
SOURCE: Printer Error
Insert Printer Driver Disk And Uninstall The Printer Driver completely. Dont Remove It From Control Panel. You May Use Uninstaller Software. Here's The Link http://wugnet.com/shareware/spow.asp?ID=638. Install this and remove printer driver. Delete temp and prefetch files as well if you wish. Disconnect Ur printer from the computer and turn it off and then disconnect the power cable. Press n hold the POWER BUTTON on the printer for 30 seconds so that static is released. Disconnect all the cables from the back of the computer and then Press n hold the POWER BUTTON on the Computer for 30 seconds. Restart Your system and hook up the printer and visit the following website
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26321&infoType=Downloads.
Choose Ur OPERATING SYSTEM and then DOWNLOAD AND INSTALL the latest driver software and firmware.
Restart Your System.
Issue Would Be Resolved..
Plz Rate The Solution Accordingly....
Posted on May 22, 2009
sherlyn c
  • 134 Answers
SOURCE: Scanner error
Press the On button to turn off the Stylus Photo RX500. Unlock the transportation lock. Make sure that all packaging materials have been removed. Turn on your Stylus Photo RX500 again. If the error message still appears, call Epson so they can replace your printer.
Goodluck.
sherlyn C.
Posted on May 24, 2009
How can I replace the scanner glass on my Epson Stylus Photo RX500?
Usually it is cost prohibitive to repair, as replacements are similar to repair cost.
Sep 29, 2010 | Epson Stylus Photo RX500 Printer
Epson Stylus PHOTO RX500 - PRINTER ERROR message
keep pressing the button, until it stops where you want.
good luck
Mar 21, 2010 | Epson Stylus Photo RX500 Printer
Epson Stylus Photo RX500. I was cleaning print head when I got "printer error" message. The load eject light is on. I've unplugged printer, turned it on and off. no luck. solutions?
Press all these buttons:
Power+Load/Eject+Stop+B&W+Color
When printer turns ON, "Init eeprom" appears
Release and Press the Color button.
Jan 06, 2010 | Epson Stylus Photo RX500 Printer
Scanner error
Goodluck.
sherlyn C.
May 23, 2009 | Epson Stylus Photo RX500 Printer
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Mar 10, 2009 | Epson Stylus Photo R200 InkJet Printer
Turning on the device ERROR
Try resetting the EEPROM
Turn the printer off.
Hold down the Stop, B&W, and the Color buttons.
Press the ON button.
The LCD screen should flash 3 times.
Release the Stop, B&W and Color buttons
Press the Color button again.
Then turn the printer off and back on.
Nov 01, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus RX500
Turn printer off.
Sep 17, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo RX500 Printer Logo
207 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
