Question about JVC GR-D20EK Camcorder
JVC GR D20EK Condensation operation paused
GR D20EK "Condensation operation paused". I have tried to dry it out for days over a gentle heat with no change. Is it a software problem?
  • vsphome Feb 22, 2009
    When i wants to use my camcorder and i'll start him up, i've the same description "Condensation operation paused, please wait". Afther about 30 minutes, it's working. When i put in the cassette and i turn the camcorder for using it, the same problem is there and i have to wait aigain about 30 min.
    How can i result this problem ??
  • 153 Answers
SOURCE: Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Posted on May 26, 2008
SOURCE: JVC CAMCORDER
I have the same problem and I need a solution. Please, can somebody help?
Posted on Dec 27, 2007
SOURCE: Please wait -Condensation operation Paused
Always happens when I go to Scotland to visit my daughter.
Solution - I take it to bed pugged in & switched on. It's so warm in the morning it works!
pootle 1944
Posted on Mar 28, 2008
  • 3 Answers
SOURCE: condensation operation
Here is how I fixed mine
JVCgrd70u Condensation problem fixed
Hope this help,
Louis
Posted on Jul 12, 2008
zohail
  • 1223 Answers
if no picture on screen and u are unable to record it might be a CCD failure due to manufacturing fault in this series kindly see the link below u can get it repaired free of charge or tell me the resion u are in and i will give u direct link for support pls rate me FIXYA or ask more help
http://www.jvc.co.uk/template.php?page=100102
Posted on Mar 20, 2009
you can try gently drying it with a hairdryer not too close or too hot but try to get the moisture out that is causing your problem. this could have been caused by coming in from the cold to a warmer room. this should fix it.
May 07, 2010 | JVC Cybercam GR-D90 Mini DV Digital...
Remove power from the camera. I remove the battery as well. In the back of where the tapes go, on the left side is a silver component. It's just behind a metal roller that hangs down from a plastic piece over the head. If you look behind the roller diagonally across where the tape goes, you can see a black square on the right side of the silver component. Clean this (gently!) with a moist cotton swab. The swap should get a bit of black gunk off. I'd recommend cleaning it with a dry swab next to remove any moisture. Wait a minute or so to be sure it's dry. Then re-apply power. You should not see a false condensation message for a long time.
Mar 13, 2010 | JVC GR-X5 Mini DV Digital Camcorder
Jvc gr d50.. "condensation, operation paused"
Set it in a bowl of rice for a couple days or leave it out in the open air till it works again. Do not use a hair dryer or any type of pressurized air source. The rice works for cell phones that take a dip in a water source too.
Eric
Jun 19, 2009 | JVC GR-D50 Mini DV Digital Camcorder
Condensation operation of camcorder paused
Condensation problem is a common on newer camcorders. It is the sensor on the board that detects the condition of humidy. If you have not wet the camera or stored it in the humid area, the sensor or components around sensor is faulty. You can try to dry any humidity using hair dryer at medium setting in about 6 inches away for less than 5 minutes toward inside of tape loading area (make sure loading mech is at opened position). If this does not work, take it to recommended local camcorder repair facility for a diagnostics. Good Luck. CRJ
Feb 28, 2009 | JVC Cybercam GR-D93 Mini DV Digital...
JVC VIDEO CAMERA CONDENSATION PROBLEM
Please eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC Video Cameras
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Camera on charge
You may have more than one problem.The battery may not be charging,which is a power supply problem,secondly the loading motor is not fuctioning due to connection problems to the servo pcb.
Apr 06, 2008 | JVC GR-D20EK Camcorder
Jvc dew sensor
Just switch the camera on and leave it like that for about 1 hr.. It will clear automatically!
Dec 02, 2007 | JVC GR-D20EK Camcorder
Help me please....
try removing the battery and take a clean soft cloth and gently wipe surface.
Jun 21, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
JVC GR-D20EK Camcorder Logo
363 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
