Question about Philips 60P8342 60" Rear Projection Television
60 in Philips television model# 60P8342
We got this television for free because it was having problems working for a while and then shutting off. we brought it home, my boyfriend cleaned out all the dust and then turned it back on and it worked great for two weeks, and now it starting up again. It will work up to 5 hours then shuts off sometimes it will turn on right away, but this time it wont turn back on. Just hoping someone might have an idea what is wrong to save us alot of money to fix it. You know times are tough. thanks
    Problem Solver:
  • 7 Answers
Well let i can try to help ya ...ok....check the output transistor .....check shorts to the flyback tansformer........chaeck see if there is a open or cold solder in the fuse or around the fuse anywhere ...check to see if the power comes on at all ....also ive seen where the power plug was loose and someitmes made contact and the sometimes it did not......anyhow hope this helps.....just a few check points ..could be something else but i would check these points out first
Posted on Feb 04, 2009
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2010 | Philips 60P8342 60" Rear Projection...
Autolock on my philips magnavox 60p8342
I am sending the user manual to your email address it will explain the auto lock procedure.
Jun 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
My Philips 60P8342 TV wont turn on
Does the led blink or is it constantly solid? Let me know cause if its blinking thats an error code.
May 06, 2008 | Philips 60P8342 60" Rear Projection...
Flyback?
you will need to order a new one its pretty easy repair. We have them for most models in stock on the other site . is your model a 60P8342? If so this should be your flyback0fab5ff.jpg
Mar 29, 2008 | Philips 60P8342 60" Rear Projection...
64p8342 Powers up,but no picture.
Try resoldering the vertical output IC have seen many of this model have hairline cracks on the vertical IC solder joints causing blanking of the CRTs while audio still worked.
Mar 13, 2008 | Philips 60P8342 60" Rear Projection...
No remote Philips 60P8342
I checked with my parts distributor = remote sensor no longer available.....Philips part # 932215244687...........................T.
Dec 19, 2007 | Philips 60P8342 60" Rear Projection...
Philips 60p8342
Probable bad sensr inside tv.....Philips part is no longer available
part # 932215244687..................................................T.
Aug 30, 2007 | Philips 60P8342 60" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
