Question about Refrigerators
I have a Whirlpool(Model: GS6NBEXRL01) Side-by-Side has a sensor on the right side of the freezer and a flap on the left. The light is red and the icemaker is making ice, but will not dispense through the door. What is wrong with it?
  • Refrigerators Master
  • 4,654 Answers
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see "Ice
Maker & Storage Bin."
• Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
• Press and hold LOCKOUT a second time to unlock the
dispenser.
Let me know if this is your problem, Can get the manual for you if you like, Sea Breeze
Posted on Feb 05, 2009
  • John Tripp
    John Tripp Feb 05, 2009
    The ON/OFF switch is located on the top right side of the freezer
    compartment.
    • To turn on the ice maker, slide the control to the ON (left)
    position.
    • To manually turn off the ice maker, slide the control to the
    OFF (right) position.
    Style 2:
    The ON/OFF switch is located on the ice maker, behind the ice
    maker cover door.
    • To manually turn off the ice maker, flip the switch to the
    OFF (bottom) position.
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
I had that problem before and it is happening now, whirlpool side-by-side stopped making ice. last time it was a problem with infrared light, can you tell me how to check for it? there is infrared eye that...
Yes, when you open the freezer door, the small red light should start to flash, you should see a flap on the left side wall, push it in so it is flush with the wall, now the eyes should see each other and the red light should go to a steady on, put your other finger over the other eye on the right and the red light should start flashing again, if not then you most likely have a eye malfunction. Hope this helps, Rick
Jul 28, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Our Whirlpool Gold Refeigerator Model GD5YHAXNL 03 has stopped making ice at the normal rate. It only drops about a dozen cubes in a 12 hour period (versus a complete fill normally). I noticed the infrared...
This is a WAG, but I would suggest you try to align the two sensors until there are green lights on both sides. According to the instructions, it is to operate like the garage door sensors. When the sending unit beam hits the receiver unit, you should get green lights on both sides.
Someone might have jarred one or the other unit out of alignment, and you might not need any parts to fix it.
Jun 10, 2011 | Whirlpool Refrigerators
Sounds like marbles or ice dropping in refrigerator (not freezer side). Looking into vent in back upper left corner, noise seems to coincide with a flap going up and down. The flap movement is being...
The flap is what open and closes to allow more or less cold air in from the freezer. There could be ice buildup inside the freezer causing this or a mechanical noise of the flap and motor running. See if you can see it from the freezer side of the vent.
May 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool icemaker microswitch location
If the icemaker is still in the refrig ,(easily removed with 1 screw ) pour about 2/3 cup of water into it . Also check the black fill hose which is above the icemaker fill cup , to see if it is frozen closed . If the icemaker dumps the cubes , and doesn't refill with water , replace the water inlet valve behind the refrig . If it doesnt dump the ice , replace the icemaker . My parts site is down , or I would give you part numbers for the water inlet valve and the complete icemaker .
The laser light should flash 2 times , pause , flash 2 times etc , if working correctly . If the laser light is not on , then the icemaker is in the harvest mode . If it stays off , icemaker is bad . If you close the flap on the left side of the freezer , the light should go off , until you release the flap . If these factors are ok , then the optics are ok .
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool GS6NBEXRL Side by Side...
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool gold GS6NBEXRL01
hi .thanks for the question . the defrost cycle is probably on. either that or a faulty thermostat. thanks the appliance doc rate me please
Sep 10, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
391 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
