Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG DISHWASHER TE ERROR CODE
WHEN I HIT START IT GIVES A TE ERROR CODE
  • 640 Answers
You have 1 of 3 problems...the water is to hot over 140 degrees..your thermister went open,,or you have a bad pc board,,(control) onthejob
Posted on Feb 04, 2009
3 Suggested Answers
  • 5 Answers
SOURCE: ERROR CODE "TE"
I had the tE error code on my dishwasher LDF7811ST and noticed that with the door half open the error would not appear. I faked the door being closed (pushed in the top latch (can be unlocked by pulling out with a paperclip after the test) after which the washer worked fine: suspected the wiring harness. Removed the stainless steel front and discovered quickly that 1 wire was cut (might have made contact with the door half open), 2 wires to the point where the insulation was gone and the bare conductor exposed (!)and 2 more were about to to be cut completely! I soldered and shrink wrapped the wires and the problem was gone. Made some pictures for evidence and plan to contact LG as this is a fire hazard!
Alexander
Posted on Jun 04, 2009
ZJLimited
  • 17970 Answers
SOURCE: LG dishwasher LDF modle 7811st
TE error code means Thermistor Fault or Inlet Water Temp too High.
Check the resistance of the thermistor (located on the bottom of the unit in between 2 orange wires with single spade connectors which is the heating element) and it was good 11.7K ohms at 71 degrees room temp. Take the front door off and trace wiring. There is a white plastic wire loom and approx.6" up check the wiring being melted in the black mastic. The thermistor wiring is red and dark blue.
Generally, some lose or broken wires cause this. Keep us updated.
Posted on Jun 27, 2011
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
What does te3 error message indicate?
Hi Pamela, Search online for "error code te 33" and follow the hits generated.
Jul 11, 2015 | Dryers
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Samsung NE595N0PBSR range is giving error code "tE"
te error code is (touchpad error). you have to replace the touchpad assy. the board and overlay.
Apr 06, 2013 | Samsung NE595N0PBSR 30" Electric Induction...
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher LDF modle 7811st error code tE just gives erroe code will not start.
Jun 27, 2011 | LG LDF6810ST Stainless Steel Built-in...
Error code tE, customer service recommended replacing thermoster, replaced but still getting error code. Can it be something else or does something have to be rest?
Ive looked through a service manual for your washing machine and that give the exact same fault and solution you mentioned (tE = Heater Error - The THERMISTOR is out of order)
Here is the service manual for you to look at:
WM-2277HW Service manunal
I had to scroll down to the troubleshooting section though but it has everything you would need to know in it.
I hope it helps
Regards
Mike
Mar 24, 2010 | LG WM-2277HW Front Load Washer
I'm getting an error I cannot find in the book.
The "half E" is supposed to be a T. The code is TE, and means "
Thermistor trouble or very high inlet water
temperature. (over 194℉)" Some people have posted possible solutions on this site.
Jul 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
TE error code on my LG WM2688 washer. Thought I started cycle, went downstairs. Checked back and noticed it never started and had a tE error code on screen. Manual says, unplug and call for service. ...
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 29, 2009 | Washing Machines
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
1,479 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
