Carrier Infinity with existing ducts
Hi
I Have 6 Infinity a/c systems that I bought for another project and didnt use them. I want to use them in my personal house but was told that they system may shut down with the existing duct work in the house. I really need to use them and I am willing to take some risk but I dont know how likely this is to happen.
Thanks,
Bob
  • Perry Putnam
    Perry Putnam May 11, 2010
    What size is the A/C? If you don't know tell me the Model #. What is the square footage of the house?
    Problem Solver:
  • 17 Answers
If the duct work is to small the unit cannot get enough air flow and will shut down on pressure faults.
Posted on Feb 10, 2009
Red heating tab stuck. How do I remove the front plate to access tab. Carrier Infinity System.
I know the infinity, but I have know idea what a red heating tab is. Can you be more specific?
Mar 23, 2017 | Carrier Heating & Cooling
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
I have a condensor Carrier model 38ck030300. It is old and I cannot read how many tons it is. I probably need to replace it with new. Do you know how many t it is? Which units will be...
The unit is 2.5 ton system. many units can replace the existing, you can upgrade to a 3ton if you wish without problems or upgraded ducting if enough ducting exist.
Brands that will almost fit as is are Payne, Day and Night, Rheem, Ruud.
Jul 26, 2011 | Carrier 38CKC036 Air Conditioner
CARRIER INFINITY WEATHERMAKER WHERE IS THE RESTART SWITCH
Carrier Infinity systems, do not have a manual reset switch. It will have an automatic reset depending on the failure.
I would first, turn off the breaker to the indoor and outdoor units. Wait about 5 mins and turn the breakers back on. Doing this will reset the Control Board in the system. The system itself, is probably locked out.
This should get the system to come back on, However, you may have the problem come back and lock out the system again.
If this happens again, i would advise calling a Carrier dealer with Infinity systems to test it.
Hope this helps
Brian
Nov 28, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the...
if you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Aug 04, 2009 | Heating & Cooling
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
The Infinity Comfort Control code
Call your local Carrier dealer. They have code to get into system. Rusty Good system
May 21, 2009 | Heating & Cooling
Carrier Infinity System Thermostat...The actual temp remains a constant 79 degrees. This seems to have occured after a recent power loss. AC and heat are functioning properly, but must be turned on and off...
Call your local company and check the warranty status on the Infinity UI it should still be under warranty and get a replacement otherwise it could run you a couple hundred dollars
May 03, 2009 | Carrier Heating & Cooling
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
