Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
My HE4 Clothes Softner won't dispense
Can't get the softner to dispense while washing. Any suggestions from anyone?
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
When putting softner in after loading clothes, the fabric softner runs out onto clothes before washing cycle begins
The part that puts softner in at the right time might be stuck open or broke. Have it looked at or see if you can find the problem.
Jan 23, 2014 | Kenmore Washing Machines
The fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
Aug 11, 2009 | GE Washing Machines
Maytag MTW5620T2 the fabric softner despenser doesn't despense. There is mositure inside and it slings fabric softner everywhere. It leaks from the side hole of the agitator. Gets fabric softner on my...
Liquid Softener was clogged up over time.
1-Put hot water in the place of the Softener slowly and let it over flow to dissolve the solidified liquid.
2-Keep doing this until you see water at the bottom of the tub.
3-Run a small load to clean out the gum.
Jul 02, 2009 | Maytag Washing Machines
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Fabric softner still in draw when wash finished
There is a blockage in the dispenser that is causing the prob.
Remove drawer from dispenser, and thoroughly clean every part of it, taking all the pieces out to do it.
To test it is working, put it back together, and before you put it back in, fill the conditioner compartment with water until it starts to overflow, turn water off, and the remaining water should continue to run out, until it is empty, if it does not , then it is still blocked.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Washing Machines
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
