SOURCE: Logitech cordless mouse red light won't go off - New Batteries
Check the bottom of the mouse for a connect button. Push the connect button and it should work.
SOURCE: Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
SOURCE: how do you change the batteries logitech V450 mouse?
Hey,
Scroll down this page to get the user manual, then right click on it and save as.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=5173&p_created=1153350122&p_sid=Lrb7Vkwj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0zNCwzNCZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1WNDUwIExhc2VyIENvcmRsZXNzIE1vdXNlIGZvciBOb3RlYm9va3M*&p_li=&p_topview=1
if you can't open the user manual follow instructions on the page to install adobe reader.
The user manual has pictuers on how to replace the batteries.
Let me know if you need anything else.
Thanks and good luck.
Ekse
SOURCE: change battery
If it is cordless, it has batteries. You can usually tell if the small red light is off on the bottom.
Most mice have the battrey compartment in the rear half of the top of the mouse. The rear half slides off. Something like this:
Yours will probably hold 2 AA batteries. If it is one of the smaller ones it may have the battery compartment underneath and take 2 AAA batteries.
Hope this helps.
Thanks for using Fixya.
