Question about Casio WK110 Portable Keyboard
Keyboard is dead how do you check for the fuses in kw3500 casiop
Ssterry128@aol.com
  • 741 Answers
First I would check to ensure it is the keyboard and not the port on the motherboard. Get a working keyboard and plug it in if it works then you know it is the keyboard and not the motherboard.Turn the keyboard over remove the back cover and check for a fuse in the +5VDC. Just as a hint: on these types of keyboards the fuse will blow if you unplug or plug it in with the power on...if changing the fuse does not fix it then the motherboard has to be replaced as you cannot change the port. Let me know if you have any questions.
Don't forget to rate this solution before you log out.
Posted on Feb 04, 2009
How delete browser history in the aol settings how can I do this
To clear your footprints from the History panel:
  1. If the History panel is not open, hold the Ctrl key on your keyboard, then tap the H key.
    Note: You can also access the History panel by clicking the History tab on the side panel of the AOL Browser window.
  2. Click the Clear My Footprints button.
  3. Click the Clear Footprints button, then click the OK button
Appuals com Apps and Manuals Library
Sep 05, 2014 | aol.com Computers & Internet
N.j.b.c.candc@aol.com
Step 1 Tap the "Mail" app on your iPad's home screen, tap "Other" and tap "Mail Account." If you already have an email account set up, tap the "Settings" icon on the home screen, tap "Mail, Contacts, Calendars" in the sidebar and tap "Add Account."
Step 2 Type your name into the "Name" box using the onscreen keyboard. You can enter any name you want; your iPad sends this name with each email you send.
Step 21 Type your full AOL email address in the form "Name@aol.com" into the "Address" box. If you have an AOL email address with a different domain, such as "@games.com" or "@love.com," use that domain instead.
Step 31 Enter your AOL email password into the "Password" box.
Step 41 Type a description for your email account into the "Description" box and tap "Next."
Step 51 Tap "IMAP" at the top of the New Account pane.
Step 61 Type "Imap.aol.com" into the "Host Name" box under "Incoming Mail Server."
Step 71 Type "Smtp.aol.com" into the "Host Name" box under "Outgoing Mail Server."
Step 81 Enter your full AOL email address into the "Username" boxes under both "Incoming Mail Server" and "Outgoing Mail Server."
Step 91 Enter your AOL email password into the "Password" boxes under "Incoming Mail Server" and "Outgoing Mail Server."
Step 101 Tap "Next." Your iPad verifies the settings.
Apr 16, 2014 | gmail.com
Lost all power to the stove and oven
First, make real sure your main (house) circuit breaker box breakers are not tripped. You should have one listed Range oe kitchen stove. It's a 220v so it has 2 circuit breakers tied together. Flip it off and then back on. Then recheck to see if the stove/oven has started working. If not, you may also have an internal fuse in the back of the stove (normally inside the back cover). I would recommend you have a service man check this as the voltage inside the range is deadly if you make an error. ALWAYS UNPLUG THE RANGE BEFORE WORKING ON YOUR RANGE. Another problem could be a wire burned off inside the range and may need replced. If you are going to fix it, look for a wire/s that look black and burned. Whatever you decide, just BE CAREFUL
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 13, 2013 | Kitchen Ranges
Does vision singing machine have a fuse
Try checking in these:
http://search.aol.com/aol/search?&s_qt=sb&q=vision+singing+machine+owner%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
http://music.manualsonline.com/manuals/mfg/the_singing_machine/the_singing_machine_karaoke_machine_product_list.html
Jan 21, 2013 | Audio Players & Recorders
I dont have installation disc for an m-audio radium 49 ttmiller81@aol.com
Use this link under keyboards.
http://www.m-audio.com/index.php?do=support&tab=driver
Oct 07, 2010 | M-Audio M AUDIO RADIUM USB KEYBOARD...
Isn't there a way to delete all inbox mail on AOL? It seems silly that you have to delete one message at a time.
if you are using the AOL software/program, open your mailbox, select the very first e-mail from the list, then press and hold down the SHIFT key on the keyboard and click the very last e-mail. This highlights all e-mail in between. You can then press the DEL/DELETE key on your keyboard
if you are using the webmail (available on AOL.COM), you will see a box at the very top column of the mail folders, selecting it will select all e-mails, then press DELETE key or click the DELETE button
Jun 09, 2010 | Microsoft Computers & Internet
I am unable to connect to aol. Screen says invalid password. This has been going on for weeks. I have changed passwords numerous times. In the past the new one works for a few days, then the whole...
Hello!!!
Check Your Keyboard Connection, Then Restart Your Computer
Checking the connections and restarting the computer will make sure the keyboard is plugged in properly and the computer is correctly recognizing the keyboard.
To check the keyboard connection and restart the computer:
1. Shut down your computer:
* If using Windows® 98 or Windows® Me, click the Start button, then click Shut Down. In the What do you want the computer to do? section, choose the Shut Down option by clicking it, then click the OK button.
* If using Windows® XP or Windows® 2000, click the Start button, then click Shut Down. Click the What do you want the computer to do? drop-down menu to open it, choose the Shut Down option from the list, click it, then click the OK button.
2. Follow the cord from the keyboard to where it plugs into the computer.
3. Unplug the keyboard cord.
4. Wait for about 30 seconds.
5. Plug in the keyboard cord.
6. Turn on your computer.
Nov 05, 2008 | Computers & Internet
No power
This problem is about impossible to answer as the information is too vague to decipher. If the set is completely dead, the first place to check is the fuse. If you care to add more information about this, feel free to call me at my shop 307-266-4675 or email me direct at wyoed1@aol.com and I'de be glad to help as I can.
Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 24, 2008 | Televison & Video
Dead mouse port
Had u checked it with new mouse..
If showing same problem.. u need to replace the motherboard..
Nov 19, 2007 | Compaq Presario 5000 PC Desktop
Casio WK110 Portable Keyboard Logo
416 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
