Question about HP Pavilion dv1000 Notebook
No Lamps with battery
I've got the typical DV1000 issues of working-not working but I also have an additional issue. When it does work, the lamps will not come on when the battery is used. I have to start it up using AC in order for everything to run fine. But if I turn it on using ONLY the battery, everything comes up and the OS loads and can continue working but the LAMPS will not come on at all. It'll be on for hours with the lamps off. Any ideas, any one???
    President:
  • 1,223 Answers
Ur LCD is faulty try changing it with a replacement or a new one used are also available try on EBAY check ur inverter of LCD that cable that carries image to lcd but strong chance of LCD fault 100%
Posted on Feb 20, 2009
Help Only one headlight working
It could be a broken wire on the wire harness or a bad fuse.
Mar 11, 2014 | BMW 1 Series Cars & Trucks
Dashboard light go in and out
incredible, is car running or not?
EG: key on only.
EG key on end running.
Gee! pretend the helper is blind, we are..
there are 2 kinds CLUSTER of lights
1: WARNING LAMPS. (all com on keyon as test)
2: AND PARKING LAMPS. that can be dimmed....
3: and gauges they too use CLuster power so....
which ones.?????????? name all lamps and bad.
does engine run??????????
do head lamps work and not be dim?
we need all lamps that work and not.
both.
your car electronic tech, would see all this in 5 minutes work , I say let them'! not me im retired.
A primary test, for power.... (works key off too)
if head lights are dim or fail?, or act odd
that is a dead/week battery (or just discharged)
or just ignoring the terminal lug cleaning service steps. (that is a top failure, "A1" failure.
also modern cars with lots of computers!
they all go very crazy, with low battery voltage.
use a thing called a voltmeter to check system volteges. battery is 12.6vdc rested.
even the $10 walfart, meter works. here. prefect.
and running, 13.3 to 15vdc good. is it?
Jan 28, 2014 | 2005 Suzuki Forenza
I have a f 250 superduty 7.3 1999 , the rear running lamps are not working but all others do. please help i 've checked fuses but didnt find any bad , also replaced bulbs just in case
Had a similar problem with my 97 power stroke. somehow the plug in the wiring harness below the bed at the rear of the truck vibrated loose I had all lights but brake lights. Or it may be a ground wire issue. Good luck. Let us know how it works out.
Nov 08, 2012 | Ford Cars & Trucks
My passing lamps and headlights keep burning out and now this morning my headlight and passing lamps are out all together. Does anyone know what is causing this on my 2005 Heritage Softail Classic? I...
Hi Tony, obviously there is a problem in your light circuit. For your lights to keep burning out you have either to much voltage/amperage getting to them or a loose or broken ground in that front light circuit. I would first do a charging system test at the battery, voltage at 3000 RPM'S should be 14.3 to 14.7 volts anything higher replace the voltage regulator and make sure it has a tight clean ground. Other than that you will have to check all your wiring and connections from the ignition switch to the passing lamp switch and the high/low beam switch for worn or chaffed wires and corroded, broken or loose pins. To aid you in this perilous journey please visit the website below for a free wiring diagram and good luck
Harley Davidson Wiring Diagrams and Schematics
Oct 04, 2011 | 2000 Harley Davidson FLSTC Heritage...
2001 Monte Carlo SS 3.8 v6 Rear park lights are out as well as the dash lights, brake lights work headlights work front running and park lights work, all turn signal lights work. replaced headlight switch...
Park, Tail, Marker Lamps, and License
The park, tail and marker lamps, including the license lamps, turn on when the headlamp switch is placed in either the PARK or the HEAD position, or anytime the headlamps are requested. The RT I/P #1 fuse in the RH I/P fuse block supplies battery positive voltage to both the park lamp relay switch contacts and to the park lamp relay coil circuit. The park lamp relay coil is controlled by the body control module (BCM). When the headlamp switch is placed in the PARK position, the BCM energizes the park lamp relay coil control circuit.
Current flows from the park lamp relay switch to both front and rear park lamp fuses and to their respective park/tail lamps. The front park lamps are grounded at G101. The rear park lamps are grounded at G302. The license plate lamps are a part of the rear park lamp circuit and are grounded at G302. The inadvertent power control feature prevents the park lamps from remaining on more than 10 minutes if left on. If the park lamps are turned on after the ignition switch has been turned OFF, or is in the ACCY position, they will remain on until turned off or until the battery runs dead.
Did you the REAR PARK LP fuse 15 amp in the right insturment panel fuse box.
Jul 18, 2017 | 2001 Chevrolet Monte Carlo
Replaced lamp in 55vg825 approx 1500hrs ago & lately the picture has lost brightness compared to when the new bulb was installed. Is there another adjustment or is the bulb defective already? Past...
bjac,
You are correct about lamps working or not, but that is the extremes. Over the course of operation all lamps lose brightness as the hours add up. All lamps will lose their brightness over time.
Typically lamps only last at best 6000 to 8000 hours. That is not long if the unit is used most of the day everyday. In addition the cheaper the quality of the lamp, cost and manufacture, the quicker they go down hill.
Assuming that you have a low quality lamp what you are experiencing is normal. You may be able to improve the brightness and clarity of the picture by cleaning the lenses, mirrors and screen. I have a tip at
http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv
This tip is labeled projection tv but is also appropriate for cleaning an LCD or DLP unit.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 14, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
My tail lights for my 2002 ford f-150 doesn't work.
When you say tail lights, is this the parking lamps or the stop lamps ?
If it is the parking lamps:
Do the front ones work ?
Do you have power at the 4 pin trailer tow adapter for the parkign lamps ?
- If not could be the fuse for the parking lamps, engine compartment Fuse panel, Fuse # 6.
If this is the stop lamps, try raising the tilt all the way on the steerign wheel, and see if they work again ( this is if the truck bed ones do not work and the CHMSL / 3rd brake lamp does work ).
- Some times the connector can be pulled apart, causing issues with the brake lamps on the truck.
Mar 05, 2011 | 2002 Ford F150 Regular Cab
1996 Ford Taurus GL 2000 3.0L 4V Battery Issues?
you need to get a adapter from any auto store that can handl e load you want
Jul 09, 2009 | 1996 Ford Taurus
Turn signals not working in front
you have a shor in the steering colum typical in gm cars... replace the whole coulm
Jul 09, 2009 | 2002 Pontiac Bonneville
Hp DV1000 backlight flickers on then off on button press
If you go to this site you can get step by step instructions. The lamps and inverter aren't really that hard to replace if you can follow directions and have patience. Good Luck, hope this helps.
Jan 17, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
