It looks like you've got a plain, old "480i standard definition" TV. The inputs
on it will likely be limited to S-Video, RF Coaxial (cable) and one or
more sets of "A/V" inputs that consist of 3 jacks - 1 each yellow, red,
and white. Without knowing the make & model of the TV I can't be sure which / how many inputs it has. It looks like you're trying to play a DVD. Most DVD players only offer A/V type connections - again - you didn't provide this info so I'm forced to guess. The Yellow jack (on TVs and disc and tape player / recorders almost always provide the higher quality A/V jacks) is for the video signal and the Red & White are always the left and right stereo audio jacks. The cables used to connect devices to the TV have the same colored plugs to make matching them up easier than if they were all the same color. If you accidentally connected one of the red or white audio plugs into the yellow video jack, you will not have a picture. Check BOTH ends of the cable - at the TV and at the DVD player. All three plugs must be connected to the corresponding colored jack.
If it is connected properly, your DVD player might be one that was a more expensive type that offers "480P Progressive Scan" output along with the standard "480i interlaced scan" output. The 480i output was called "standard definition" and 480P was called "enhanced definition" and provided a better picture. If your TV only supports 480i, it will not be able to display a 480P signal. You will need to check the DVD Player manual to find out how to return the output to 480i again. If you no longer possess the manual, you may either Google it or provide the brand and model here so that we might take a look for it for you.
In the event that you are using RF coax (cable) to get the signal from the source into the TV, you may just be trying to watch it on CH4 instead of CH3 (or vice-versa). Try changing the channel up or down one from where it is to see if the picture comes in.
I hope this helps & good luck!
