Question about OKI C3200n Led Printer
No toner message
Replaced three toner cartridges...but, printer still says no toner. should all four cartridges be changed and how can you tell which one is out?
  • bref298 Feb 24, 2009
    i have the same problem. I was told i need to order a new drum
  • 4 Answers
The control panel display will indicate which toner is out;
K = Black
M = Magenta
Y - Yellow
C = Cyan
Also, the orange indicator light will flash.
Generally, each toner will provide about 1,500 copies depending on the intensity of the specific color. The toner drums, on the other hand, generally provide more than 20,000 copies each and need not be changed that often.
When you change a toner, included with the toner is a little alcohol wipe that you use to clean the toner sensor. This is a small LED located along side the toner holder. Make sure ALL toner waste/dust is cleaned off the sensor before installing the new toner.
Also, while I hate to state the obvious, make sure you removed the tape from the new toner before inserting it. Last, make sure you lock the toner in place with the blue lever. And it never hurts to shake the toner a little side to side before inserting it just in case the toner has gathered at one end.
Last, there is a utility included with the printer that lets you access the printer's information via your computer. This will tell you exactly how much toner is left in each cartridge and the life remaining on the drum.
Posted on Mar 14, 2009
All four toner lights blinking
it could be that you need to replace all the toners. I do not own this kind of printer, but if it is the same as my inkjets, you have to replace all empty cartridges or it still wont work. try replacing the other toner and see what happens.
Nov 08, 2013 | Konica Minolta Magicolor 1600W Printer
I have Samsung CLX 3175 laser printer. Am getting invalid toner message although parts are genuine
Well, eventually I worked it out: The "contacts" are four square fields to the left on on the backside of the cartridge. And it works instantly. (I read somewhere that it needs to be fully transparent tape. The 'blurry' tape leads electricity and doesn't work.)
Mar 13, 2012 | Samsung CLX-3175FW Multifunction Laser...
How would i know which color of toner is need to change?
The life of the toner cartridge yield depends on the amount of toner that print jobs require. The actual number may also be different depending on the print density of the pages you print on, and the number of pages may be affected by operating environment, printing interval, media type, and media size.
If you print a lot of graphics, you may need to change the cartridge.
The machine uses four colors and has a different toner cartridge for each one:
yellow (Y), magenta (M), cyan (C), and black (K).
    The status LED and the toner-related message on the display indicates which each individual toner cartridge should be replaced.
    Trust this helps. Please vote. :)
Dec 11, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
My toner was low, so I replaced printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Aug 30, 2009 | Sharp MX-2300N Color Copier
Toner exhausted replace toner in Laser Printer SCX-4300
My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
Mar 25, 2009 | Samsung SCX-4300 Monochrome Laser...
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to...
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Feb 22, 2009 | Dell 3100cn Laser Printer
Replace black toner
Does the message say Replace, or Reinstall a subtle difference, but it does matter.
If it says Reinstall, the problem is that the printer is not making electrical contact with the three small copper pads on the side of the cartridge. Wipe to remove any toner etc, and when you re-fit the cartridge 'wizzing' it back and forth a couple of times usually works. If it doesn't, look at those contacts - do they look neatly in line - none of thembadly mis-shapen ?
If it says Replace, is the cartridge a new OEM one - if so its faulty
If its a remanufactured one, the reset fuse probably wasn't replaced.
If you refilled it yourself, are you thinking what's a reset fuse ?
The reset fuse is what 'tells' the printer a new cartridges has been fitted, and zeros the count for that cartridge.
Sep 09, 2008 | Samsung CLP-500 Laser Printer
Not recognizing toner
Shake the toner cartridges.
Make sure the connections that are on the printer for the cartridges are clean.
Jun 17, 2008 | Dell 3100cn Laser Printer
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
OKI C3200n Led Printer Logo
283 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
