Question about Alesis MasterLink ML-9600
Corrupted playlist... hdcd to reset... tried that.. doesnt work
First i was getting a message that said corrupted track... was told to hold "create cd" and "utility" buttons while powering up..
upon doing that.. the hard drive formatted itself.. then when i thought it was going to give me the normal start up screen.. it showed corrupted playlist hdcd to reset.. but nothing happens when i press it...
  • 37 Answers
Either the HD is bad or you will need to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
hope this helps
dave
Posted on Jun 24, 2009
I had the same problem.....but reading your post helped me with my corrupted file. I just powered up like you said and immediately held the create cd button and utility button. I held it until the formatting was finished. problem solved....but lost some music in the process. Charlie Woo.
Posted on Jun 16, 2009
I have a dvd/mp3 insignia surround sound, only the red standby light is lit, the other parts are not lit up in their traditional blue light, no digital readout screen that says hello or good-bye, nothing.
pls. advise
Posted on Feb 04, 2009
I have a Sony Walkman Atrac AD and cannot make playlists with it. There is the option, but how do i put music on them?
The only way to add playlists on this unit is to use your PC software to create them and then add to the unit later. you cannot create a playlist on the player itself.
you can use any music software to create and add. for instance, If you are using Sonys own Soundstage, follow these instructions:
Click "My Library"
Click "create/edit PLaylist"
Select the tracks you want from content shown on left. ( to select multiple tracks at once, hold CTRL key)
Select the "New Playlist" on right
The new playlist will be created. you can rename it now
click on large arrow pointing left
Now just import this folder to your player
you are done.
Here is a link to the user guide
http://www.docs.sony.com/release/NWHD5_english.pdf
Thanks
Please rate FIXYA
May 25, 2011 | Sony NW-HD5 MP3 Player
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
I can't add tracks to any of the playlists that I've created!
Are you creating playlists with Musicmatch or are you creating them directly on the DJ?
Let's say you have a playlist on your DJ and want to add a track to it. First, play the playlist. While it is playing, go to Music Library, find the track you want to add, select it with the thumbwheel, one of your choices in the menu that comes up is "Add to Selected". Select "Add to Selected". Now when the DJ reverts back to the screen showing the track being played. Hit the thumbwheel twice. A menu comes up. Select "Save as Playlist". Name it. Then delete your previous version of the playlist. Your new version will include the track (or tracks) you added.
Okay, that answered your specific question, but let me tell you it is much easier to build and organize, and yes, edit and/or add to your playlists from musicmatch.
After loading musicmatch, up near the top is a button called playlists. On its menu, select Playlist Manager. The window that opens has buttons that will let you create new playlists or modify old ones. You can dock your dj and edit the playlists on it from here or build playlists and then Send them to Portable Device (your DJ) Fairly easy.
Mar 01, 2009 | Dell DJ MP3 Player
CD Burning
i would try to dl latest nero.com use nero alot better did u try to go to roxio.com and download latest software verison k thx nick
Oct 06, 2008 | Roxio Easy CD & DVD Burning
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
System error
you may need to change the hard drive.
try ebay for a 30 or 40 gig.
dave
May 27, 2008 | Alesis MasterLink ML-9600
IT READS ERROR 181
Hard drive crapped out. Send it back for repair.
May 05, 2008 | Alesis MasterLink ML-9600
I have an mp3 player and i need help creating playlists and deleting
The below was copyed froma an earlier post of mine, read the bottom. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R Playlists can be created by puttung your music in separte folders within drive f:, each folder will show up as a playlist. Good Luck
Sep 17, 2007 | RCA Lyra RD2762 MP3 Player
Trouble Filing Songs into Playlists
ok, sounds like a problem I had when I was working out the software! The easiest way to create a playlist with the Zen, is doing it over your PC, if you don't have the software it is available for FREE download at the official creative Zen site, just choose your model and region then hit download- simple! (You won't need Zencast with sleek photo model) ok! install your software blah blah blah, once it's gone through that process, restart your pc and then plug in your zen. the software should instantly recognise that your player is connected, so now, you can open up the software via desktop shortcut or start menu. From here, you've got a whole ton of options, whether to add to your library, create playlists etc etc. Choose create playlist and the process is easy. Left side of the screen is navigation of your Library, right side is navigation of current playlists. Create a new list, then name it. From the top left of the screen, select a folder on your library to open, the lower left displays what's in the folder you are viewing. move tracks over accordingly, holding down ctrl while you click is a fast and easy way to select more than one track at a time. hit add in the center of the screen to move stuff over to your new list. when you're done, save it. when you exit the software and unplug your zen, it should take a minute to update itself, sometimes you may need to restart Zen also to get the playlists updated. I hope this helps!
Apr 19, 2007 | Creative Labs ZEN SLEEK MP3 Player
File Error message
Sounds as if the players system is corrupt, you will either need to find factory reset or use the software that came with it to format the player.
Mar 09, 2007 | Sony NW-E107 MP3 Player
Alesis MasterLink ML-9600 Logo
711 people viewed this question
Top Alesis Televison & Video Experts
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
