Question about Philips Standard 105S Monitor
My screen adjustment buttons aren't working properly
How should i ajdust my screen without using screen adjustment button
  • 283 Answers
Other way to adjust your screen right click on desk top then press properties then settings. thank you....
Posted on Feb 05, 2009
Broken volume button, in-call volume won't go up
Hit volume down then use on screen slider to move it up it will appear at top of screen to the right is volume up.
Feb 09, 2014 | Motorola Mobility MILESTONE XT720 Cell...
My LGHD1209 the buttons aren't working properly, sometimes the power button responds when pushed but no others....
Try unplugging it and waiting 10 mins for any capacitors to discharge. Switch back on and retry buttons. If no go, control panel fault
Apr 28, 2012 | LG LWHD1209R Air Conditioner
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
My brightness menu is locked on the screen and my monitor buttons aren't working .. I'm having a silver Samsung Syncmaster 720N.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 10, 2011 | Samsung SyncMaster 720N Monitor
Have a 16" dell flat screen monitior. The display are very dim,and make for hard viewing. Tried to push buttons on computer but a locked icon flashes up. Tried holding the buttons to unlock but did not...
You need to hold the menu button for 15 seconds until the lock icon changes to unlock. Then you should be able to adjust the brightness of the monitor, assuming that the backlight is working properly. Hope this helps you.
Jul 29, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
The OSD and SET buttons on my monitor are not working properly. is there a software that can help me adjust the screen digitally i.e. without the need of those buttons?
I used to work at a company that specializes in CRT and LCD refurbishing. If a CRT's buttons have gone bad theres nothing you can do other than having them physically repaired.
Jan 24, 2010 | LG Studioworks 775N 17" CRT Monitor
How do I adjust and balance the air flow intake and fuel ratio?
if your xv is carbureted you can ajdust that mixture by changing the jets in the carb. ir its fuel injected then you won't be able to ajdust mixture and shouldnt need too either. jetting a carb can be lengthy explanation so let me know.
Jul 25, 2009 | Yamaha 1900 XV 1900 A Midnight Star
I cannot increase the volume and it is very low. I have tried using all the tools that I can find but to no avail.
I know this is an old post, but since it's the first Google result that shows up, here's the solution:
On the Q19wb press the '1' button, then use the arrow buttons to highlight "Audio Adjust" and press the '2' button to select. Then highlight and select "Volume" using the arrow keys and the '2' button. Then, adjust to a higher volume using the up arrow button.
Note: if you aren't getting any sould from your monitor follow similar steps above but select "Mute" and "Off" in the options.
Jun 24, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Philips Standard 105S Monitor Logo
211 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
