I have a new hp laptop and hooked up to att through a 2wire modem that has wireless router onboard when I hook the lan cable in I get internet but when I unplug it and try to go wireless no internet this is the only computer I have any help would really be appreciated.
1st
Look for a wireless network, it will be named 2wireXXX (XXX = the last 3 digits of the serial # on the bottom of the 2wire modem.)
When it asks for a WEP or a security key, it will be on the bottom of the modem in between 2 bar codes and it will have [ ] around it, this should be a 10 digit #.
If that does not work.
I had a problem with my MAC and my Windows VISTA 64 BIT Laptop not being able to keep a stable connection with the default wireless username and password. To get into the 2wire: Open a Internet window Address Bar 192.168.1.254 Home network "At the top of the page" then click on wireless settings "Also at the top of the page" Then you are in the wireless config to change the information. What i had to do is change the wireless authentication to WPA-PSK and change the wireless password (Use a 10 digit Number as the pass-code, a phone # would be a good suggestion) , what you also need to do is change the name of the network along with the channel of the wireless, it helps if you take it all the way up to 11. Then you should be smooth sailing all the way. :-)
