Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Run(heat) for a certain minutes then it stop.
Heating/cooling unit- Run for a certain minute then it turn-off
We have a roof heating/cooling unit carrier model no. 48tje006, ser.No. 3499g21132 and it prompts at the panel 4 red light flushing means- "4 consecutive limit switch faults". What does it mean this problem? It is the thermostat problem need to replace?.Please answer and give me an idea howto solve.
  • Ken Bledsoe May 11, 2010
    I should have given you a explanation of the code you have. Get back with me if you want to know as you haven't answered my question yet you might have found out already. ken
    Is your filter clean?
    Problem Solver:
  • 11 Answers
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Posted on Feb 09, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Tip
Ductless Heating and Cooling of the Hard to Duct Home
You are <b>building a log home</b> or a home that you want the rustic look of the <b>floors above also being the ceiling of the floor below</b>. You hate the thought of having to install ugly <b>heating and air conditioning ductwork</b> in your new home. For you there is hope. You can still have a comfortable home and have the look that you want.<br /> <br /> The advancements in <b>ductless heating and cooling</b> has made it possible for you to have those wood ceilings, roof lines, wood walls, and everything you can think of. The new <b>ductless HVAC units</b> take up very little space on your wall. They can be placed almost anywhere with a little planning, and they are<b> very efficient at both heating and cooling</b>.<br /> <br /> The many features do not stop with the<b> heating and cooling</b>. Most units have remote controls to run the unit. Many of these units can run <b>multiple inside units from one outdoor unit</b>. These units are so quiet that you have to feel the air coming from them to see if they are running. The installation has been simplified to the point that they can be installed very quickly by an <b>experienced professional</b>.<br /> <br /> If you are concerned about the looks on the outside, that too can be fixed rather easily. The <b>piping and wiring going to the indoor units</b> is relatively small and can be hidden in many ways by using a little imagination. Colored aluminum can be fabricated to cover the pipes. I have also run the piping through rain spouting and made it to look like just another rain spout coming off of the roof. <br /> <br /> If you are looking to build or remodel and are worried about the look you will have on the inside, then take a look at <b>ductless split heat pumps</b> to give the comfort and the looks.<br /> <br /> Good<b> heating professionals</b> can find many ways to make these units work for you. Make sure that you do not settle for something less than you want. You may need to look at more than a few companies to find the one that will give you the system that you want.
on Feb 19, 2011 | Heating & Cooling
My lg sensor dryer will run for a little while then shut off and will not turn on for about 30 minutes. Takes hours for one load
Could be over heating and the unit shuts down till it cools off. Check the dryer vent line for clogging all the way up to the vent by the roof. Bet it is clogged some where and that is the cause of your problem.
Nov 05, 2015 | LG Dryers
Indoor fan will not stop
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Jun 19, 2014 | Goodman CKL36AR36 Air Conditioner
Fan failure /Intermittent heating
quite likely your microwave is trying to prevent it self from self destruct, because if the fan is not keeping the electronics components cool enough while its running the high limit thermo will disconnect power from the heating circuit, if the fan is not working it should be replaced , that's a techs job.
Feb 12, 2014 | Microwave Ovens
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
SPLIT AC NOT COOLING AFTER 30 MINUTES
sounds like the out door fan is not running and the comp is over heating, rec to start unit and check to see if the fan is running in the first 30-45 min, if not check cap or replace fan motor.
Jul 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Dryer starts (heat on) after 5-8 minutes heating cycle stops and only cool air run through.
your heating element need to be cleaned.......
1. pull the unit out from the wall
2. Remove the screws holding on the larger rear panel.
3. Using a vacume cleaner extension, remove as much debris as possible from all accessible components.
4. Clean out the dryer vent and the connection to the wall, making sure that air can pass easily.
THAT SHOULD DO YA. If the heat continues to cut off, you are dealing with a faulty heating element in which case you will be best off to purchase a new dryer. (replacing a heating element is typically the beginning of a failing unit)
GOOD LUCK AND PLS RATE THIS POST!!!
Jun 03, 2010 | Kenmore Dryers
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
240 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
