Question about Classic Electronics CDR201 CD Recorder
CLASSIC CDR201 HELLO I HAVE A CLASSIC CD RECORDER MODEL CDR201. IT HAS DUBBED FOR ME IN THE PAST, BUT RIGHT NOW I AM IN A CRUNCH AND IT WILL NOT DUB A SINGLE TRACK FOR ME. I AM IN A BINE AND I NEED SOME HELP. ALSO, IS IT SET TO ANALOG AUTOMATICALLY HOW DO I GET THIS THING TO DUB A SINGLE TRACK. I CAN'T MOVE FORWARD WITH THIS THING ACTING UP. THANKS- G
4 Suggested Answers
SOURCE: need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
Posted on Jun 18, 2008
  • 99 Answers
SOURCE: I purchased the wrong cd's
you need to buy cd-r's/cd-rw's marked "COMPACT DISC DIGITAL AUDIO" you may have bought cd-r's for use on a PC only as these can't be used on a home audio recorder unless they've been prerecorded on a PC. hope this helps?
Posted on Mar 18, 2009
SOURCE: I need to find the correct brand of recordable
Any CD-R will play, if your player is picky about the recorded discs, make sure you record it at a very low speed. 2X is optimal but very few actual recorders support such speed, try the lowest one.
Also use high quality discs like Verbatim, the best ones have a blue background on the record side.
Posted on Oct 27, 2009
How do I get my Sony RCD-W1 to record from one CD to another
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
Dec 09, 2012 | Sony RCD-W1 2-Disc CD Recorder
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
I need to find the correct brand of recordable cd's for this model. Classic cdr201 recorder
Oct 27, 2009 | Classic Electronics CDR201 CD Recorder
I have a classic cdr201 recorder, when i go put a disc to record it says WRONG DC? i need to burn cds
you need cd-r music cd not the computer ones.
i have model cdr200 works with the ones that say music on disc.
hope that helps
Jan 27, 2009 | Classic Electronics CDR201 CD Recorder
How do I record on my Harman Karman I can't remember?
Put a blank cd in the right deck; put the one you are recording from in the left deck. Close door. Punch dub.. after it scan all the tracks, then punch play/select on the right hand side, then it will dub it for you. Once it gets thru dubbing; hit finalize - lights blink twice, then hit finalize again. once lights go out it's finished dubbing and you can play it back to hear your recording...
Dec 22, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Classic Electronics CDR201 CD Recorder Logo
202 people viewed this question
Top Classic Electronics Audio Players & Recorders Experts
jairo sanchez
Jonathon summesfield
jasbo
jasbo
Are you a Classic Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
