Question about True 31 cu. ft. / 878 liter Commercial Freezer TR-31F
Convert freezer to refrigerator
I just bought a T-23F Model true freezer. I would like to make it work as a refrigerator not a freezer. Is there a way to do this? What parts do I need? I was thinking I would have to just replace the thermostat. Thanks for your help!
  • roger398 Feb 04, 2009
    Ya, it sounds wierd but my dad bought it from a auction company that didn't really say what it did. So he wanted a fridge not a freezer so we are kind of stuck with it for now:)
  • 30 Answers
Converting a freezer to run like a fridg can be done ,however it is sometimes tricky. you have to replace the thermostat, you will also want to shorten the defrost time setting. and may have to disable the fan delay to let the evaporator fans run all of the time, to prevent short cycling of the compressor.
Posted on Mar 07, 2009
    Genius:
  • 2,920 Answers
You may be able to turn it down to its lowest setting to get what you want it to do. i have never heard anyone that wanted to make a fridge out of a freezer before now.
Posted on Feb 04, 2009
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Apr 06, 2013 | True T-23F 23 Cu. Ft. 1 Door Freezer
True freezer model t -23f need wiring diagram
There is a safety cutout on the evaporator that sometimes goes open circuit, stopping the heater coming on in defrost.If the compressor will not turn off, check the condenser is clean.and the fan working. next check the thermostat hasn't broken. Lastly, check the defrost timer.
Dec 27, 2012 | True Freezers
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
I have a True T 23f freezer that I know needs a new defrost timer. My problem is finding the right one. The only numbers I can see on the timer are 8141-00B and 345-00. I can also see it's marked 2hp...
That 8141-00B is a Paragon timer model number. If you get the identical one you can just mark the numbers down and be sure to wire in the new one the same way.
Nov 11, 2010 | True 23 cu. ft. / 651 liter Commercial...
My True 23F has had extensive work performed since I bought it used. On two separate occasions, it worked well for a month, then shut down. At this posting, the compressor will not come on at all. ...
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
this should take you to their site for a manual on your freezer. I has info on the time clock and how to set it.
First, be sure it has the correct power to the unit. I would then check the temperature control. Be sure it is sending power to the compressor unit. If a contactor is used, is the coil on the contactor getting the correct power? Start there and let me know if we need to go further. Good Luck
Sep 12, 2010 | True 23 cu. ft. / 651 liter Commercial...
We bought the Commercial Freezer T-23F last month and the unit never works right, we had a service persons came in to fix it two time, both time they fix the defrost timer and it still the same. The...
Is it factory new, never been used? Or are you saying you bought a used one and they replaced it with a "new" used one? I am familiar with True Manufacturing and if it is a new unit you have a one year parts and labor warranty. The dealer you bought it from is the responsible party to fix your problem.
Aug 29, 2010 | True 23 cu. ft. / 651 liter Commercial...
T-23f not freezing
Depends on how technical you want to get. Generally, measure the ambient temp of air entering the condenser coil. Add 30 degrees to that temp and convert to psi using a P/T chart. This will get you to a starting point.Remember, charging a "Hot" box takes time. Don't over charge.
Oct 27, 2009 | True Freezers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
NEED CAPILARY TUBE. WHAT SIZE HOW LONG. TRUE
have ready a correct make and model number and call 1st source at 1-800-392=3939. if u can't get it there, who knows. plz rate me.
Jul 27, 2009 | True 23 cu. ft. / 651 liter Commercial...
True 31 cu. ft. / 878 liter Commercial Freezer TR-31F Logo
1,467 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
