OS Name Microsoft Windows 7 Ultimate Version 6.1.7601 Service Pack 1 Build 7601 Other OS Description Not Available OS Manufacturer Microsoft Corporation System Name DJSCORPIO-PC System Manufacturer TOSHIBA System Model Satellite A205 System Type X86-based PC Processor Intel(R) Pentium(R) Dual CPU T2390 @ 1.86GHz, 1867 Mhz, 2 Core(s), 2 Logical Processor(s) BIOS Version/Date TOSHIBA V2.50, 6/11/2008 SMBIOS Version 2.4 Windows Directory C:\Windows System Directory C:\Windows\system32 Boot Device \Device\HarddiskVolume2 Locale United States Hardware Abstraction Layer Version = "6.1.7601.17514" User Name DJScorpio-PC\DJScorpio Time Zone Central America Standard Time Installed Physical Memory (RAM) 3.00 GB Total Physical Memory 2.99 GB Available Physical Memory 1.66 GB Total Virtual Memory 5.98 GB Available Virtual Memory 4.27 GB Page File Space 2.99 GB Page File C:\pagefile.sys
Why do you want to update the BIOS of your laptop? Be careful about updating your BIOS because it might cause your computer to crash.
Or are you trying to update the drivers in your computer?
If you are having some issues with its performance, then you need to update all the outdated drivers in your computer. I know that it's a total headache if you do the update manually but don't worry because there are Automatic PC Updater like RadarSync. It will scan and update all outdated drivers in your computer.
I hope this helps!
David
Testimonial: "Thank you very much. Read your advice and gave it a thought. Needed to update. The RadarSync helped me out."
SOURCE: Toshiba laptop Dual display issue
To switch between screens try pressing the FN key and F5. You should not have to restart you computer. As for the TV error "invalad signal" you might have to change the screen resolution on you computer. You might have to try a few different resolution before you find one your tv accepts.
1.
Open Display Settings by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2.
Under Resolution, move the slider to the resolution you want, and then click Apply.
SOURCE: Dual Processors for Toshiba Satellite A205-S5000 533Mhz FSB
you got a cheap laptop. maybe from walmart or some other store that was selling it for about $400. It doesn't have a processor that you can switch out. I'm sure it's horribly slow for Visa, so my advise would be to sell it and get something with a dual core.
SOURCE: same problem, i downgraded it to XP. Now i cant
Hi
Thank you for your query
Please try the following
1) Go to www.devicedoctor.com and download and install the software
2) Load up the program and then click on 'begin scan'
3) This will scan and hopefully pick up the missing drivers for your sound
4) Click on download for the sound drivers
5) Install the drivers and enjoy
I hope this has been useful
SOURCE: Dear Sir/Madam, I did attempt to
you need a new dvd drive. they aren't expensive and they're easy to replace
