Question about Reddy Heater-30-55,000 BTU Variable
Will not ignite after replacing air filters
Unit runs, purchased filter kit for 55K Reddy Heater Kero. Unit has spark but will not light. Replace new filters with old filters and unit fires up. Swapped out a second time and sure enough it will not light. Put old filters back in (clearly filter is carboned up) and unit fires up.
  • james berkhimer May 11, 2010
    sounds like the air mix is too high w/ the new filter the unit needs to be choked
    Genius:
  • 1,036 Answers
Clearly a problem with the new filter.
Does it have a check valve built in?
Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
Thank you.
Posted on Feb 04, 2009
Have a R35a that was stored with kerosene for 2 yrs. Electric motor runs and it tries to ignite. belches some smoke and heat intermittently then just blow air
your pic is a propane heater but model # a kero heater any way check lines to the air and fuel for cracking filters have to be clean in the heater and foam on the out not sure what the pressure is for that model but findable table on the ready heater look up get the old fuel out and new in good luck ready was the best
Nov 30, 2013 | Reddy Heater-30-55,000 BTU Variable
I have a master heater b150b 150,000 btu kerosene heater motor and fan blowing and i can see tho igniter lighting but it seems like no fuel been sitting awhile it will not light
jason2713,
Provided that you know the unit has sufficient fuel and there is no dirt or water in the fuel you have a classic All Pro, Reddy Heat, Master Heater, etc problem. They are all made by DESA International and similar in operation. They control fuel pressure by bleed air. As the air filter plugs up the pressure changes and that is why your unit runs with the top off. You allow more air to flow. You need to replace the air filter and set the pump pressure. I have a tip at
http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters
which is written for Reddy Heaters but as I said before they are all the same. It tells you how to complete the repair and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mar 03, 2011 | Reddy Heating & Cooling
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater runs then stops
it's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater RM60 HSI Forced Air Heater: Pump Pressure Issue!!
ground wire on the circuit board needs to be checked and these units need to have a GOOD three wire cord with a proper grounded outlet
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
RM115 Reddy Heater forced air heater problem
air pressure should be no more than 3.5 psi. could be your pressure is too high and is blowing out the flame.
Dec 05, 2007 | Reddy R155D Utility Heater
All Pro Heater
most parts for kero heaters are interchangable. go to desatech dot com for parts. check for a reset button for your heater. if no reset, does the fan run? your unit can use one of two ignition parts. a spark generator with a spark plug or a hot surface igniter. the unit uses a cad cell flame detector. you might need to replace this.
Nov 18, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater-30-55,000 BTU Variable Logo
82 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
