I also have the same problem with my 52 inch rca projection television. the tv will turn on somtimes, and other times the green light will turn on and off 3 times and nothing happens. this tv is only 4 yrs old i would like to save it if possible? isereau@gmail .com I also have the same problem with my 52 inch rca projection television. the tv will turn on somtimes, and other times the green light will turn on and off 3 times and nothing happens. this tv is only 4 yrs old i would like to save it if possible? isereau@gmail .com
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
it is easy to fix. get your self a case of beer and a fifth of jack and then look for cp 150 cp120 and cp114 as i did after pulling the star shaped screws out of the back of the t.v. and then finally throw the damn thing in the back yard and shoot it
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair. http://servicemanuals.vstore.ca/
when the processor on the set detects a problem it will shut the set down for safety. it could be many things. technicians have a device that can read the errors that the processor has detected.
Hi,sounds like a 2200 35v cap on the high voltage power supply,this board is the left one facing the back of the unit,the cap is located behind the u shaped heat sink it is green in color,if it is bad the top will be pushed up,make sure to unplug set before serving,hope this helps
yeah i have torn into a few other tvs already. I just need to know be done
are u able to work on it yourself?
