Question about Minolta Office Equipment & Supplies
AUTOMATIC FEEDER BELTS FOR AF-5 MINOLTA
Dear Sir,Madam
I am looking specification for the belt used in AF-5 in minolta copiers, I need to buy these belts about 100 pieces but no luck can you help please.
Best regards
Bosief
  • bosief Feb 07, 2009
    Thank you I am looking for the belt only and not for the whole units, Yes they are old model type AD-5 part no:4426-5501-02 .
    Best regards
    Bosief
  • Minolta Expert
  • 1,326 Answers
Are looking for the part number? It is 4433-3513-01. The AF-5 you are looking for would it go on a EP-2050 & 3050 & 4050. It is a duplexing adf. If that is what you are looking for they are old copiers..... I think 1994 or so. You may not find them. Did you check with Presicion Rollers on line.... Good Luck
Posted on Feb 07, 2009
How to clear the display error on konica minolta c452
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Dec 06, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Konica minolta c 35 keep saying missfeed was detected
Sir/Mam, Which paper draw or is it the bypass tray? Or the document feeder? Are you using the correct paper type.. Clean the rollers with some alcohol. Two per draw. two rollers for the docfeeder
Jan 13, 2014 | Minolta Di251 All-In-One Printer
Having c-143e when connecting adf to di 620. When i remove adf socket and restart the error goes away and machine works fine
Sir, It is the document feeder, the Di620 is a very old MINOLTA machine, but you mite find a (NOW) Konica Minolta dealership that can update the document feeder EPROM (Erasable Program able Read Only Memory) chip located on the document feeder control board. It has to have its program updated to correct this problem which gives this code. Let them know you have the Technical Bulletin # 2617b they will not be able to call it up but mite be able to contact some one at Konica Minolta tech support that can get access to very old MINOLTA technical bulletins. Additional info is Knowledge Base # TAUS0645133EN00. Then will have to hope that Konica Minolta has keep the Firmware for the chip????? Maybe in JAPAN!!!!!!!!!. YOUR ASKING ALOT TO GET THIS MACHINE TO RUN!!!!
Mar 30, 2012 | Minolta Office Equipment & Supplies
Minolta DiAlta model 151f, when i try to use the automatic paper feed on the top of the machine the paper goes in about half way then stops then a message comes caution original doc jam
Try cleaning the pickup wheels that pull the paper into the feeder. There might be an electrical sensor problem also that is not sensing the right paper size. So lets start with cleaning the feeder
Jan 04, 2010 | Minolta Office Equipment & Supplies
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
Looking for Digital Camera to use lens
Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
DYNAX 5D / Maxxum 5D
DYNAX 7D / Maxxum 7D
Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
LOST 1350W Installation disk for my konica minolta pageprog 1350W
well patel... you would find it on konica minolta web site itself....
here is the link... juz choose the operating system and install your drivers...
http://printer.konicaminolta.com/support/current_printers/pp1350w_sup.htm#drivers
Sep 21, 2008 | Konica Minolta PagePro 1350W Laser Printer
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Konika Minolta Bizhub 7228
Have the document feeder rollers been replaced? Also how about the Clutches for above rollers been replaced?
Jan 04, 2008 | Office Equipment & Supplies
69 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
