Question about Whirlpool Duet GHW9150P Front Load Washer
Frigidaire stackable front load washing machine
My washing machine is no longer draining. It starts the cycle but then stops mid-cycle and doesn't continue washing or drain. My model is GLGH1642FS.
  • Anonymous Feb 06, 2009
    After the cycle completes, the washer slowly fills with water. It does not happen every time, and it has fixed itself when I reset the breaker as the manual suggests. However, it has become more regular of late and resetting the breaker no longer is fixing the problem. Do these machines have bad pumps? Is this one working intermittently possibly?
  • 640 Answers
Ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
Posted on Feb 07, 2009
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
I have a Frgidaire Gallery series front loader washing machine. It just started pausing itself mid cycle. I have to keep checking on it and repress the start button. It doesn't seem to be spinning...
I have the same problem ,, and i called frigidair and they didnt seem to care my unit is only a year old ,, im so furious right now ,, now i was looking on the recall list and the water pumps are on the recall list on selected models i know with mine it will stop then pause and not drain the water out ,, maybe some can help us out :)
Sep 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Seems to be going through the cycles but when it gets to the drain it makes a noise and the water doesn't drain - it is a front load stackable
Might be something in the pump...its pretty simple to check....just disconnect the washer, lean the washing machine back against the wall.....make sure its stable of course and take the clamp off...its to the right...then get a flashlight or put your fingers in and check...
May 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Stackable Front Loader Washer
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Oct 04, 2006 | Frigidaire GLGH1642DS Front Load Stacked...
Whirlpool Duet GHW9150P Front Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
prem mathew
